Old 01-24-2011, 10:18 PM   #1
Basement insulation question
In a ranch type home does the floor need insulation in the basement to keep the heat from going underneath
Gates is offline   Reply With Quote
Old 01-24-2011, 10:20 PM   #2
Experienced
Jackofall1's Avatar
Heat rises, no insulation required, but you might want to have heat in the basement, plumbing likes it better that way.
Old 01-24-2011, 10:25 PM   #3
Plumbing likes it better that way ?
Old 01-24-2011, 10:27 PM   #4
Experienced
Jackofall1's Avatar
Anything below 32*F, will freeze water, hence, plumbing likes it better that way
Old 01-24-2011, 10:33 PM   #5
Ok yesterday it was like 5*F and water was running perfectly
Old 01-24-2011, 10:37 PM   #6
Experienced
Jackofall1's Avatar
I am sure it wasn't that cold in your basement.
The short of it, you want and need heat in the basement.
Old 01-24-2011, 10:40 PM   #7
I need heat the house is jus 600 sq ft but the basement is about half that would that be exspensive to do
Old 01-24-2011, 10:44 PM   #8
Experienced
Jackofall1's Avatar
No, heat added to the basement rises, keeps the floors warm, which in turn keeps the rooms warm.
Old 01-25-2011, 12:57 AM   #9
Thanks jackofall !! Oh do u think the house needs more radiator
Old 01-25-2011, 02:51 AM   #10
I quite agree with you. That's a good idea.
londeed_leung is offline   Reply With Quote
Old 01-25-2011, 03:05 AM   #11
How much radiator is needed to heat the size house I mentioned
Old 01-25-2011, 03:10 AM   #12
This one of the bed room
Old 01-25-2011, 08:02 AM   #13
Pro Flooring Installer
rusty baker's Avatar
Why don't you post this in the right forum? This is the flooring forum.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 01-26-2011, 02:57 AM   #14
If the crawlspace underneath the floor is to be insulated what the best insulation and method to use ?
Old 01-26-2011, 02:27 PM   #15
Quote: If the crawlspace underneath the floor is to be insulated what the best insulation and method to use ?
Expandable foam sprayed on the wall of the crawl space. Also pressure activated vent in the cooling./heating system. The vent opens slightly when the heating/cooling is on and closes if off. This helps to keep crawl space temperature closer to the indoor one and and also drier crawl space. Effectively the crawl space, if sealed properly = the vent holes need to be closed and sprayed over as well, will have slightly positive pressure.
At least this is what we had done in our house 6 years ago and it works well.
stary kozel is offline   Reply With Quote
basement with garage insulation question WS6transAm General Discussion 7 01-21-2011 07:15 PM
blow in insulation question Cool user name Remodeling 4 12-31-2010 12:24 AM
rafter insulation question Jeremy Hillary Boob, PhD Building & Construction 7 08-02-2009 09:19 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 06:21 PM
yet another insulation question bobbyhill Building & Construction 2 12-06-2006 01:01 PM
