Old 10-18-2009, 10:49 PM   #1
Default Basement Flooring Recommendations
Hello All;
I just had asbestos tiles removed from my basement and I want to install new basement [COLOR=blue ! important][COLOR=blue ! important]flooring[/color][/color] over the concrete but there are so many types that I'm confused about which type is best for my particular situation.
I have pets and want to be able to clean up their mess easily and not have it soak in and the smell to linger.
I do have water backing up onto the [COLOR=blue ! important][COLOR=blue ! important]floor[/color][/color] once every three years or so due to roots getting into the pipes and clogging them up. While I quickly take care of this problem when it occurs, I do want the flooring hopefully nbot be afected by water backing up once in a while.
I want something durable as I will have a few heavy shelving units sitting on top of it.
I want something easy to clean, and something that looks nice.
There is a slight imperfection in the concrete that makes a section look slightly sunken. It was very noticeable in the [COLOR=blue ! important][COLOR=blue ! important]asbestos [COLOR=blue ! important]tile[/color][/color][/color] that was removed.
Any suggestions about what type of flooring would be good in my situation ?
Is there any type of flooring I should stay away from ?
The handyman I have do work for me suggested Allure tile (Sold by Home Depot) but one of the flooring dealers I visited yesterday said that a floating floor is a laminate which could get damaged with water/mess from a pet and did not recommend it. The dealer instead suggested a vinyl tile. What do you think ?
Thanks for your suggestions/recommendations.
wtdedula is offline   Reply With Quote
Old 10-18-2009, 11:08 PM   #2
Ceramic tile.
Old 10-19-2009, 12:48 PM   #3
Originally Posted by wtdedula View Post
Hello All;
I just had asbestos tiles removed from my basement and I want to install new basement over the concrete but there are so many types that I'm confused about which type is best for my particular situation.
I do have water backing up onto the once every three years or so due to roots getting into the pipes and clogging them up. While I quickly take care of this problem when it occurs, I do want the flooring hopefully nbot be afected by water backing up once in a while.
There is a slight imperfection in the concrete that makes a section look slightly sunken. It was very noticeable in the that was removed.
Allure Tile would be a good solution in this case, assuming the floor is flat. Since it is a vinyl product, any bumps will telegraph through. Metrofloor makes this product as well as a plank product that looks like wood. They also make a higher end plank product called Konecto, which is thicker and has a longer warranty. You must take care when installing these products, making sure that the overlapping edges stay perfectly clean before installation or else you will have problems with adhesion.
Laminates can be floating floors, and vinyl can be a floating floor as well. Allure tile IS a vinyl tile. I think the dealer you spoke to is suggesting a peel and stick product, generally cheaper but not as nice.
Another option would be VCT (vinyl composition tile) which is heavier and needs to be glued down.
A third option would be vinyl sheet goods. (People often refer to this as "linoleum" which is a similar product but made from different materials.) Some vinyl sheets goods can be floated or glued down. A seem may be needed if the room is wider than 12 feet.
JK Floors is offline   Reply With Quote
More On This Topic
Vinyl tiles are one of the most commonly used floor coverings in homes today. The flooring comes in a variety of colors, textures and styles. Vinyl tiles are durable, decorative and easy to maintain. Follow the steps below to keep your vinyl floor in... Read More »
Alright, now we’re going to cover the tile options that there are for your countertops, your bathrooms, on the counters, in your showers, anywhere you wanna put tile. There’s a number of different options. The mosaics, which are beautiful... Read More »
How to Seal Tile
How to Seal Tile by eHow.com
Most tiles used in homes are glazed, and the glazing process creates a seal. But if you use porous materials, such as terra cotta, marble or slate, you will need to seal the tile to keep the surface looking good and to prevent stains on that surface you... Read More »
Hi! This is Steven from Keilholz Flooring on behalf of Expertvillage.com and now I am going to show you how to put the material back into the adhesive. You are going to start up by rolling the material slowly back into the adhesive. Making sure to try... Read More »
Hi! This is Steven Keilholz Flooring on behalf of Expertvillage.com and today I am going to show you the materials you need to install a ceramic floor in your basement. The first thing you need is a good drill with a good mixing paddle. The heavier the... Read More »
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 12:34 PM
Laminated flooring over basement concrete Woodcutter Flooring 1 03-02-2009 01:35 PM
Basement flooring options.. Tommy2 Flooring 9 02-14-2009 09:06 PM
Basement Flooring ... njchan Flooring 3 03-19-2008 08:02 PM
Wood flooring in basement DIY4EVER Flooring 9 07-20-2007 03:04 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
