Basement Flooring Question - Flooring - DIY Chatroom Home Improvement Forum
Old 10-22-2008, 10:48 PM   #1
Basement flooring question
Hi all, new to the forum. I currently have linoleum tiles in most of my basement (don't want to pull them up for fear of asbestos). I've done simple moisture tests where concrete slabs are exposed and so far have come up dry. I'm planning to install click laminate flooring over the linoleum tiles. My question is can I just use a foam underlayment under the laminate flooring? Or should I still use a moisture barrier with the foam underlayment? Thanks in advance for any advice.
kelot is offline   Reply With Quote
Old 10-23-2008, 11:16 AM   #2
Floorwizard's Avatar
Moisture barrier is needed.
6 mil poly will work fine.
good to go!
have fun!
Floorwizard is offline   Reply With Quote
Old 10-23-2008, 04:06 PM   #3
Thank you!
Flooring for basement with water issues Leoskee Flooring 27 08-27-2008 08:49 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Basement Flooring ... njchan Flooring 3 03-19-2008 06:02 PM
Noob question for basement finish electrical dtmbizzle Electrical 16 07-11-2007 07:08 AM
Basement flooring choices Brik Building & Construction 23 01-27-2007 02:38 PM
