Basement Flooring Question - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-16-2013, 12:58 AM   #16
Rewards Points: 150
Anyone for any or all of those questions please?
Mijotter is offline   Reply With Quote
Old 09-16-2013, 06:26 AM   #17
Not so new
12penny's Avatar
Rewards Points: 520
Originally Posted by Mijotter View Post
Ok forgive the potential noobish questions but better to ask the pros right
I am nearly done with putting up the drywall. Thus on to the next phase and have a few questions. This is a dedicated HT in a basement on concrete.:
1. Should I mud the walls all the way to the concrete floor? (Sheets are vertical) Yes
2. My riser will be an island in the room ie. will not touch any of the walls. Was thinking laying the carpet on the floor then building the riser on top of the carpet. Or should I build the riser before carpeting? Yes If so, how would I go about attaching the Island Riser to the concrete floor? Screw sleepers to floor and then attach island to sleepers. Just like a kitchen island.
3. Should the moulding where the floor meets the walls be put up before carpeting? Yes. But leave 3/8-1/2" space below baseboard for the carpet to tuck under.
4. Any recommendations on a threshold for my soundproof door, it is 2 3/8" thick? Was thinking this: http://www.homedepot.com/p/Frost-Kin...8#.UjU2rj-Hua8
I'd prefer wood, but to each his own.
5. Should the threshold go in before or after carpet? Before.
6. Should the threshold go in then the door stops brought down to the top of the threshold? Yes.
Thank you.
Hope this helps.
12penny is offline   Reply With Quote
Old 09-16-2013, 04:01 PM   #18
Rewards Points: 150
Yes it does thank you. What would be the best way to attach the wood threshold to the concrete floor?
Old 09-20-2013, 07:38 PM   #19
Rewards Points: 150
Anyone?
Also, do you line up the front of the threshold with the front of the door?
Old 09-21-2013, 02:38 PM   #20
Rewards Points: 150
-Bump-
Tags
basement , carpet , floor , flooring , tile
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
Basement flooring options markleyfamily Flooring 10 11-05-2013 05:12 PM
Wood Flooring in Basement - Yay or Nay mobiledynamics Flooring 5 10-01-2011 04:29 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 10:34 AM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 09:10 AM
