I need to put down flooring overtop of concrete in my basement. About 600 sq ft or so worth. The space is evenly divided into 2 large rooms. (load bearing wall in the middle..could remove and put in a beam..but, eh..the house is solid, why screw with it??)
Id like one room to be the "nice" side. Some nice home built furniture, nice TV, nice book cases, etc.. The other side has the washer and dryer. It can be a little more utiltarian. May still work for a game room.
My wife and I are having a heck of a time agreeing on a floor.. Personally, I think Id like to just do VCT tiles in both rooms. Its cheap, holds up well to water (in case it ever flooded), and is easy to install.
I could do a nice diaganol pattern. 2 colors with 4 squares of each color.
Whats even better, is that I have about 400 sq ft of black and white tiles sitting in the garage. The plan was to use them there..but I really need to get the house finished before remodeling the garage.
But, my Wife refers to them as "garage tiles" and thinks they are too ugly to put in a house.
I also have about 400 sq ft of laminate flooring. However, this is cheap laminate flooring. Which can often be "clicky" and not terribly attractive. The concrete floor has some slight wavyness to it. Nothing bad, but something that could be a problem with a floating floor(subfloors really need to be immaculate for floating floors). Not to mention, if it gets wet..Youre pretty well screwed. (our bsmt is dry though). Im thinking of just letting that flooring go on Craigslist or something.
Then, I think..What about ceramic or stone tile? Big 16X16 tiles arent too expensive. That would work well below grade..
Also, I think about regualar wood flooring. Maybe just put down some sheets of plywood over the concrte floor, then nail down whatever flooring I want. Anyone ever do that? Is that at all damaging to the slab? (cant imagine it being too good for it..)
Anyways, as you can tell...I have alot of options and no idea what direction to go in.
Any help is appreciated!
