Basement Flooring Options - Flooring - DIY Chatroom Home Improvement Forum
Old 02-24-2013, 07:24 PM   #1
Rewards Points: 85
Hi Everyone,
In the middle of planning for finishing my basement. Never had a water issue, but I know basements get wet. We will be doing a living area/bedroom/laundry room and I'm looking for one type of flooring for everything. Because of laundry room, I don't want to do carpet. I have been looking at vinyl planks. I was wondering if anyone has other recommendations. Also wondering what underlay people would recommend. Thanks for the help!
joshs is offline   Reply With Quote
Old 03-05-2013, 03:55 PM   #2
I second this query, with the added information that I have been looking at laminate flooring and will be covering existing vinyl tile over cement slab.
I assume a vapor barrier would be necessary, but what about padding or subfloor?
willcon is offline   Reply With Quote
Old 03-05-2013, 04:01 PM   #3
"You can do anything"-Mom
brockmiera's Avatar
Dont use laminate in a basement. If it does get wet its a total loss.
Engineered hardwood flooring, tile, sheet vinyl. All good options.
brockmiera is offline   Reply With Quote
Old 03-07-2013, 09:42 AM   #4
Amateuralex's Avatar
Rewards Points: 270
I did porcelain tile. It's not nearly as cold as everyone warned me. In fact it's barely cool, even in the middle of the winter. And we put some rugs down.
The installation was quite difficult, but I did it myself so it was free. Since I did the install myself the materials themselves were quite cheap overall. But it looks fantastic and it will last forever, and it's almost impervious to water.
Amateuralex is offline   Reply With Quote
Old 03-07-2013, 12:30 PM   #5
Rewards Points: 3,342
As previous poster stated,never use laminates in a basement,bamboo flooring is a very good choice,either solid or engineered variety,as it has very good expansion and contraction rates.
Even though bamboo is actually a grass that can be woven together and used for wood applications, it is a great alternative to hardwood flooring. It has a Janka Scale rating of 1642, which is above oak and maple and just under hickory. The scratch resistance is very high and its tensile strength rivals steel.
Canarywood1 is offline   Reply With Quote
Basement wasls, vapor barrier , options for what i have to work with bf514921 Building & Construction 3 07-13-2012 12:26 AM
Basement bedroom framing options Mesoneer Remodeling 8 01-24-2012 12:47 PM
Finishing basement - concrete walls options droyer Building & Construction 1 01-13-2010 07:27 PM
Wood flooring in basement DIY4EVER Flooring 9 07-20-2007 02:04 PM
Basement flooring choices Brik Building & Construction 23 01-27-2007 03:38 PM
