Basement Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 03-12-2009, 12:12 PM   #1
basement flooring
we live in alberta canada,very cold winters.would like most in expensive.easy floor heating ideas for excisting concrete floors,or best underlay ideas for laminate flooring without heating.also has to be moisture resident from concrete.thanks everyone.invite all proven ideas.sherry
sperley is offline   Reply With Quote
Old 03-14-2009, 01:32 PM   #2
With laminate, you'll get the best R value out of thicker planks, like the Formica Quintessa line.
Quiet Walk felt underlayment or Floor Muffler both have higher R values than many other underlayments.
Edited to add - I know you're looking at in-floor heating and I've never sold/installed it so I'm skipping that part of your question..
You should always moisture-test your floor prior to installing wood or laminate.
Have you considered carpet and pad? An 8lb pad and dense plush carpet would provide some insulation and aren't affected by average moisture; it can evaporate off from the slab right through them.
Mudd is offline   Reply With Quote
Old 03-15-2009, 07:34 AM   #3
ccarlisle's Avatar
Thanks for stepping up to the plate, Mudd.
Cuz the only part of that OP I could understand was "alberta canada"...
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Laminated flooring over basement concrete Woodcutter Flooring 2 10-25-2011 08:55 AM
Basement flooring options.. Tommy2 Flooring 9 02-14-2009 07:06 PM
Basement Flooring ... njchan Flooring 3 03-19-2008 06:02 PM
Wood flooring in basement DIY4EVER Flooring 9 07-20-2007 01:04 PM
Gameroom basement flooring? PaulMcC Remodeling 4 03-09-2006 09:08 AM
