Basement Flooring - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-20-2013, 04:22 PM   #16
Rewards Points: 31
Originally Posted by SquishyBall View Post
I'm interested in this discussion too.
For pergo type floors... snap-together... the store sells several levels of underlayment. It ranges from plain plastic sheets to felt type underlayment, to what seems like plastic sheets with tiny bits of foam between them. Since it's snap-together, there will be (hopefully) no punctures. Are there any suggestions for what features to look for?
It's Chicago, so definitely cold floor, but temp isn't really a huge concern, a little insulation would be nice, but it's mainly for protection. With low ceilings going up even 1/2" would be undesirable. Thinnest product reasonable would be preferred.
Any recommendations?
I would appreciate it if you would make your own Thread as this one is for answers to my questions.
Thanks.
ccleme11 is offline   Reply With Quote
Old 03-20-2013, 04:26 PM   #17
My apologies ccleme11; i didn't know you owned this thread.
kirkb is offline   Reply With Quote
Old 03-20-2013, 04:52 PM   #18
Rewards Points: 31
I don't... but no one likes getting email after email about something they have no interest in...
Old 03-20-2013, 05:00 PM   #19
Then with all due respect you might want to change your profile settings; if I'm not mistaken this is a public forum and all are welcome to post regardless of who started the thread.
Old 03-20-2013, 05:16 PM   #20
"You can do anything"-Mom
brockmiera's Avatar
I'm in Colorado too and I'm going with carpet right on the concrete in the basement , engineered hardwood on Platon in another part of the basement and tile on concrete in the bathroom and laundry. seems a lot overkill to put down insulation then subfloor just for carpet.
I'd say if you were going with solid hardwood that is the way that I'd go.
brockmiera is offline   Reply With Quote
Old 03-20-2013, 05:28 PM   #21
Rewards Points: 31
I just don't want it to be too cold on the bare feet..
Old 03-20-2013, 05:35 PM   #22
brockmiera's Avatar
Well is your concrete cold now? Mine is suprisingly exactly what I want it to be. Nice and cool in the summer and warm in the winter.
My buddy lives out in E470 and Gartrell and has a walk out basement. His floor is pretty cold in the winter. Mine is not a walkout though. It is all below grade. When I excavated for the bathroom drain the ground under the slab was nice and warm. that was over this winter.
Old 03-20-2013, 05:37 PM   #23
Rewards Points: 31
Yes mine is very cold now. It is below grade as well. That is why I was wondering if I needed to insulate it under the carpet.
Old 03-20-2013, 05:49 PM   #24
brockmiera's Avatar
Well I'm no flooring expert thats for sure. If its cold then I'd say yeah you should probably make it less cold before you spend money to finish it.
What about heating? Do you have a cold air return in your basement? Cold air will settle on the floor and remain there if it isn't forced to circulate. feel your bare concrete walls in the middle then up near grade. Are they cold too?
Old 03-20-2013, 09:39 PM   #25
Newbie Bill
Rewards Points: 522
Good points Brock. I would grab some old underlay and a carpet remnant from somewhere, put it down on the cold concrete floor and see if it is cold on the feet. I am pretty sure you will be just fine with the underlay and carpet.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is online now   Reply With Quote
The Following User Says Thank You to drtbk4ever For This Useful Post:
brockmiera (03-21-2013)
Old 03-21-2013, 11:05 AM   #26
Rewards Points: 31
I do have a cold air return in the basement... also, there is this 1" insulation all over the walls. should i leave it up or do i need to take it down to inspect the foundation walls?
Old 03-21-2013, 11:13 AM   #27
brockmiera's Avatar
can you step back about 15' and take another picture?
Old 03-21-2013, 11:59 AM   #28
Rewards Points: 31
The bathroom will be in the corner. Im thinking about putting a bedroom where the window is.
Basement Flooring-dsc01897.jpg   Basement Flooring-dsc01898.jpg   Basement Flooring-dsc01899.jpg
water under laminate flooring in basement ladygryffin Flooring 2 07-28-2012 11:49 AM
Best flooring option for basement flooring bristo_99 Flooring 2 11-09-2011 09:59 PM
basement flooring Master Brian Remodeling 4 05-20-2009 09:50 PM
Basement Flooring ... njchan Flooring 3 03-19-2008 06:02 PM
Basement flooring choices Brik Building & Construction 23 01-27-2007 02:38 PM
