Basement Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 03-20-2013, 12:45 PM   #1
Rewards Points: 31
Question
Basement Flooring
Does anyone recommend doing a 1" rigid foam then T & G plywood over the slab of a concrete basement floor?
If so, should it be done before or after the framing of the walls?
Thanks for looking!
ccleme11 is offline   Reply With Quote
Old 03-20-2013, 01:08 PM   #2
Floor Installer
sam floor's Avatar
Rewards Points: 154
I would not. I know some people do this, but it can make a breeding ground for mold.
sam floor is offline   Reply With Quote
Old 03-20-2013, 01:10 PM   #3
Rewards Points: 31
Even if there is a vapor barrier under the foam?
thanks
Old 03-20-2013, 02:19 PM   #4
everywhere you place a fastener in the plywood you will have a hole in your vapor barrier. over time if the moisture attacks the fasteners and they rust there will be nothing holding your plywood down. might take a long time but will still happen.
Old 03-20-2013, 02:29 PM   #5
Newbie Bill
Rewards Points: 520
You asked this same question in another thread.
I think this putting "foam on the floor and then plywood" idea came from Mike Holmes. Yes it would warm up the basement a bit, but I don't think the juice is worth the squeeze. I think there are other products out there that can accomplish the same level of comfort with less grief.
What kind of flooring do you want in this basement of yours and where do you live?
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 03-20-2013, 02:36 PM   #6
Rewards Points: 31
Carpet everywhere except in the bathroom where tile will go. I live in Parker Colorado.
Old 03-20-2013, 02:40 PM   #7
Newbie Bill
Rewards Points: 520
Where I live it is common to just put the carpet and pad directly on the concrete floor. The pad/carpet insulate the basement floors sufficiently enough in our cold climate.
Bill
Old 03-20-2013, 03:01 PM   #8
Floor Installer
sam floor's Avatar
Rewards Points: 154
I have put carpet and pad directly on floors for many years with no problems. Some of the things Mike Holmes does are not accepted by the construction and homes industries.
The Following User Says Thank You to sam floor For This Useful Post:
drtbk4ever (03-20-2013)
Old 03-20-2013, 03:24 PM   #9
Newbie Bill
Rewards Points: 520
The carpet will be fine, but I would put in-floor heat under the tile in the bathroom. Nothing like the feel of a warm tile floor.
Bill
Old 03-20-2013, 04:20 PM   #10
Rewards Points: 31
That is the plan so far... Should there be a drain in the basement bathroom floor or is that not necessary?
Old 03-20-2013, 04:41 PM   #11
Newbie here' sorry i don't have answers for you ccleme11.
But I also have an empty basement shell ....(in CA) and I'd like to finish the concrete floor as inexpensively as possible. Considering a concrete Etching Stain such as Quikrete with a high gloss sealer. My quickie budget for the 1,000 sq ft basement is about $800 or about .80 cents / sq ft. Can anyone suggest a different flooring material that would cost less?
kirkb is offline   Reply With Quote
Old 03-20-2013, 04:58 PM   #12
Rewards Points: 150
I'm interested in this discussion too.
For pergo type floors... snap-together... the store sells several levels of underlayment. It ranges from plain plastic sheets to felt type underlayment, to what seems like plastic sheets with tiny bits of foam between them. Since it's snap-together, there will be (hopefully) no punctures. Are there any suggestions for what features to look for?
It's Chicago, so definitely cold floor, but temp isn't really a huge concern, a little insulation would be nice, but it's mainly for protection. With low ceilings going up even 1/2" would be undesirable. Thinnest product reasonable would be preferred.
Any recommendations?
SquishyBall is offline   Reply With Quote
Old 03-20-2013, 05:04 PM   #13
i've seen cheap laminate for .69 cents a square foot but i wouldn't recommend it. and after you buy the under layment it would be way over .80 cents a sq foot. staining might be your best option or paint.
The Following User Says Thank You to DannyT For This Useful Post:
kirkb (03-20-2013)
Old 03-20-2013, 05:16 PM   #14
Rewards Points: 3,424
You don't want to put ANY laminate on a basement floor,the best product there would be full thickness,or engineered bamboo.
Canarywood1 is online now   Reply With Quote
Old 03-20-2013, 05:22 PM   #15
Rewards Points: 31
I would appreciate it if you would make your own Thread as this one is for answers to my questions.
Thanks.
water under laminate flooring in basement ladygryffin Flooring 2 07-28-2012 12:49 PM
Best flooring option for basement flooring bristo_99 Flooring 2 11-09-2011 10:59 PM
basement flooring Master Brian Remodeling 4 05-20-2009 10:50 PM
Basement Flooring ... njchan Flooring 3 03-19-2008 07:02 PM
Basement flooring choices Brik Building & Construction 23 01-27-2007 03:38 PM
