Old 01-06-2012, 10:09 PM   #1
Basement Flooring
What kind of wood like flooring can go in a basement on a concrete floor?
Gillykc is offline   Reply With Quote
Old 01-06-2012, 10:36 PM   #2
Missouri Bound's Avatar
Basement Flooring
Go to Home Depot or Lowes and look at the flooring. Many laminates are recommended for use over concrete but generally a vapor barrior is required. And the floor should be sealed.
Old 01-06-2012, 11:16 PM   #3
Basement Flooring
a lot of engineered wood floors can be floated, nailed down and glued down. you should check for moisture problems before deciding what floor to put down.
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 09:55 AM
Best flooring option for basement flooring bristo_99 Flooring 2 11-09-2011 10:59 PM
basement flooring Master Brian Remodeling 4 05-20-2009 10:50 PM
Basement Flooring ... njchan Flooring 3 03-19-2008 07:02 PM
Basement flooring choices Brik Building & Construction 23 01-27-2007 03:38 PM
