Old 11-25-2009, 03:53 PM   #1
basement floor rough in added, need to patch now
Hi, I just finished adding a half bath rough-in to my basement, and now am ready to repair the floor.
Are there any tricks to filling the trench? I want to ensure that the patched area does not settle at all, as I will be tiling the floor. I saw cut the edges, if that makes a difference... is it worth it to pin the new concrete to the old in some areas? any certain kind of concrete mix better than another?
06bluez is offline   Reply With Quote
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 05:44 PM
Basement Flooding / Sump Pump -- Should I get a generator added to my home. DIY_Help General Discussion 9 02-20-2009 06:36 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 11:52 PM
