Basement Floor Reno - Flooring - DIY Chatroom Home Improvement Forum
Old 06-20-2006, 06:16 PM   #1
Jack of All Master of sum
Basement floor reno
Hi All,
I have a 1987 vintage 2 story with 1/2 finished basement.
The original carpet has had it and have riped it out.
I plan to put down laminate flooring as I have never had a water problem.
Just to be sure I have duct taped two pieces of plastic to the floor for the last week (While I paint and fix poped drywall screws)
There is no moisture at all on the plastic which is what I suspected.
When I riped up the carpet they used nail strips to hold carpet in place (was real happy wasnt glued).
The nail strips were nailed to my cement floor.
When I poped all the nails up they also took a little piece of cement with it so leaving little holes.
I also notice a crack right across basement floor but not real worried cause there is no sign of water.
My basement floor is painted, should I
fill little holes and seal them?
sand floor and reseal hole floor or
not worry about it?
regards
:confused:
D.RED is offline   Reply With Quote
Old 06-21-2006, 02:20 PM   #2
Floorwizard's Avatar
I would fill the holes, check to make sure areas are flat and level, lay down 6 mil poly, then the lam floor pad and floor.
Floorwizard is offline   Reply With Quote
Do I need a HVAC return vent in basement? westing HVAC 13 04-03-2014 01:43 AM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 09:09 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 09:55 PM
Noob question for basement finish electrical dtmbizzle Electrical 16 07-11-2007 07:08 AM
Wet Basement being fixed (pics) harleysilo Remodeling 2 01-23-2007 08:09 AM
