Old 02-12-2007, 03:38 PM   #1
Default basement floor not level
My husband and I are going to install wood laminate flooring in the basement. We had radiant heat put in the basement floor when we were building and now the floor has cracked in places and is not level. How do we go about leveling the floor and is there anything simple to use like a self leveling cement or epoxy that we can use. Thanks for any help or responses given.
rjstallings is offline   Reply With Quote
Old 02-12-2007, 04:28 PM   #2
concretemasonry's Avatar
If your floor has cracked and is now not level, you have problems that could continue.
Since it is now not level, it does not sound like typical shrinkage cracks.
Find out why the floor has settled or heaved since it was built before you stat finishing.
concretemasonry is offline   Reply With Quote
Old 02-12-2007, 04:29 PM   #3
if this cracks is caused by the radiant heat... it will crack again if you continue to use the radiant heat I suppose even you seal them up... if you no longer use the radiant heat... then I suppose you can fix the cracks with concrete mix.... but crack is crack... why would crack make a floor unlevel... is it so cracky that it looks like after an earth quark.... just curious... I am by no means an expert... just curious....
KUIPORNG is offline   Reply With Quote
More On This Topic
When you're trying to save money each month in energy costs, one of the first and best places to make a change is in the hot water system of your home. Homeowners can end up spending hundreds of dollars more per year than they should as a result of an... Read More »
Bearded Dragon Heating Pads
Bearded Dragon Heating Pads by Expert Village
Next we're going to talk a little bit about is the heat pad. Now, a heat pad is a subsidiary heating device for a reptile enclosure. This should not be used as an only heating device. Heat pads do not put off enough heat, especially for a bearded dragon... Read More »
Sand Boa Cage Heating
Sand Boa Cage Heating by Expert Village
The next thing we're going to discuss is the heating for your sand boa. Sand boas are reptiles. All reptiles do need heat to some degree or another. And how we're going to heat our sand boa is with a heat pad and some heat lamps. Now, there are other... Read More »
Ok, now that we have all of our heating devices we need to talk about how to properly place them on the reptile enclosures to get your optimum heat. First and foremost, we have our day bulbs, and our night bulbs, ok. What we're going to need is we're... Read More »
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 11:09 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 11:55 PM
How to 'start' finishing the basement... mcvane Building & Construction 18 06-04-2007 10:28 AM
basement ceiling joists-how to know if they are level? yummy mummy Building & Construction 22 02-06-2007 10:16 AM
Wet Basement being fixed (pics) harleysilo Remodeling 2 01-23-2007 10:09 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
