Basement Floor Finishing: Moisture Barrier? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-28-2011, 10:10 AM   #1
Basement floor finishing: Moisture Barrier?
Hi all,
Finishing a basement and have a question about the concrete floor. When they were building my house, I was able to watch exactly how they laid the concrete slab floor for the basement. I am not sure if it is common in most areas, but basically what they did in my place is put down 4 inches of crushed drainage gravel, covered that with a plastic membrane (polyurethane I think) and then pored the slab. I was told by the builder that this is done to prevent moisture penetrating the slab.
Anyway, I am wanting to put down some laminate flooring, and was going to just put down an underlay, but while doing research, every site I go to suggested putting down some type of moisture resistant sub-floor.
So, my is this. Given how they build the slab floor, how much of a moisture barrier do I need to put down. Is a combination underlay (felt and poly) going to suffice, or do I need to use a pre-engineered sub-floor product (like thermacore or dricore)?
Thanks in advance.
junior.carls is offline   Reply With Quote
Old 08-31-2011, 05:24 PM   #2
Registered User
Rewards Points: 5,482
Welcome to the forum!
A flooring expert should be along soon. Here is some reading for you while waiting; http://www.greenbuildingadvisor.com/...cience-podcast
Gary
Old 08-31-2011, 10:51 PM   #3
Rewards Points: 200
Double felt: Two layers of #15 asphalt saturated felt paper that meets ASTM Standard
D-4869, with the first layer adhered to the slab in a skim coat of appropriate adhesive,
and a second layer adhered to the first layer with appropriate adhesive.
Floor Doc is offline   Reply With Quote
basement insulation - vapor barrier help please! cluelessloser Insulation 5 04-08-2011 03:49 PM
Finished Basement - Ohio - Moisture and Vapor Barrier cheddarthief Building & Construction 1 03-08-2011 12:19 AM
how important is it for moisture barrier to cover sides of floating floor? conradA Flooring 2 04-29-2010 10:13 AM
basement insulation and vapour barrier coolnes Remodeling 11 02-01-2009 08:56 AM
Basement Moisture problem jimdd Remodeling 1 07-22-2008 02:48 PM
