Basement Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 01-20-2011, 08:11 AM   #1
Basement Floor
I'm sure this topic has been covered but I'm not having much success with the search feature so I apologize.
I'm starting a basement finishing project and want a little feedback on floor selection. I was looking at either XPS followed by a subfloor or a tile board system with plastic channels on the underside allowing water to drain into the existing drains. My major constraint is height. From uncovered floor to joists I have 7'3" and obviously a lot of hanging pipes / ducts to deal with so space is a premium. I obviously don't want to use an inadequate system and take the chance of having problems down the road but I need to try and minimize the subfloor thickness. Some initial feedback I've received was to use a smaller layer of XPS (say 1/2").
Any thoughts on this or any other basement flooring ideas? Thanks in advance.
koz123 is offline   Reply With Quote
Old 01-21-2011, 12:08 PM   #2
Or any links if this has been discussed would be appreciated!
Vapor barrier & insulation for basement floor dvsanfor Flooring 5 09-26-2010 10:01 PM
Finishing a cement basement floor with carpet and tile - no subfloor? vseven Flooring 2 09-21-2010 09:41 AM
Leveling Basement Floor Rigid Foam mdenis Building & Construction 6 09-07-2009 04:55 PM
Paint(?) on basement floor dissolves with water Jaybone Painting 3 08-25-2008 11:51 PM
Basement floor reno D.RED Flooring 1 06-21-2006 02:20 PM
