Old 07-27-2010, 02:55 PM   #1
Basement floor
Does anyone knows if its ok to seal the basement floor before putting tiles on.
Rosi is offline   Reply With Quote
Old 07-27-2010, 03:22 PM   #2
firehawkmph's Avatar
Basement floor
Not sure if that would be a good ideal Rosi.
Are you talking about ceramic or porcelain tiles? I would just make sure clean the cement before hand and as long as there are no cracks, tile right over it.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
Rosi (07-27-2010)
Old 08-05-2010, 08:42 PM   #3
Basement floor
The answer I received was no, it is not. I had sealed my floors due to a radon issue and was told that the thinset would/may not adhere properly. I am in the middle of a laminate install and glad it turned out that way.
Oxymoron is offline   Reply With Quote
Options for Cold Basement Concrete Floor? jefferis Flooring 16 12-09-2009 01:23 PM
Leveling Basement Floor Rigid Foam mdenis Building & Construction 6 09-07-2009 05:55 PM
Paint(?) on basement floor dissolves with water Jaybone Painting 3 08-26-2008 12:51 AM
Basement Floor Finishing, Advise Needed dbbyleo Flooring 5 04-25-2008 12:32 PM
Basement floor reno D.RED Flooring 1 06-21-2006 03:20 PM
