Old 10-08-2006, 10:38 PM   #1
Basement Floor
I will be having carpet installed in the next couple of days. The old carpet pad was glued to the floor - there is a lot of residue still on the concrete. I have been trying to get it all up with a floor scraper, but it seems close to impossible. I intend to roll some water based concrete sealer before the new carpet is installed.
Does anyone here have any ideas on how to get the old glue off of the concrete?
Kyle is offline   Reply With Quote
Old 10-10-2006, 11:15 AM   #2
Basement Floor
Wire brush attachment on a hand held grinder? Use caution.
redline is offline   Reply With Quote
Old 10-14-2006, 01:19 AM   #3
Floorwizard's Avatar
Basement Floor
good idea.
Floorwizard is offline   Reply With Quote
Old 10-14-2006, 09:06 AM   #4
Basement Floor
THanks for the advice!
Old 10-14-2006, 11:09 AM   #5
Automotive Enthusiast
Sellncars's Avatar
Send a message via AIM to Sellncars Send a message via Yahoo to Sellncars
Basement Floor
Hello,
Our basement had gotten ground water during the June floods, it was also carpeted. This year we took the carpet out and the same thing, some of the old backing stuck to the concrete. I went to our local rental business and rented a floor buffer machine, there are sanding screens that you can buy for this purpose.
My basement is 26 X 17 and i went through 2 screens, probably could have used one more for the final run. This worked great, now it can be painted or whatever you want to do.
Good luck,
Sellncars
Sellncars is offline   Reply With Quote
Old 10-14-2006, 02:00 PM   #6
Basement Floor
Shovels are for more than just digging.
Grab a flat skinny shovel and go at it. I use them for scrapeing floors, and even walls when they're bad enough all the time. It's a tenth of the effort of a hand scraper and you get get a lot more power behind it.
Tmb9862 is offline   Reply With Quote
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
Basement Floor Drain amazinlittledevil Plumbing 8 01-04-2007 02:17 PM
waterproof basement floor?? patnshan Remodeling 3 09-07-2006 02:58 PM
Basement floor reno D.RED Flooring 1 06-21-2006 03:20 PM
Uneven\Buldging Cement Basement Floor SSandecki Flooring 5 12-20-2005 06:06 PM
