Basement Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 09-18-2006, 03:34 PM   #1
basement floor
I have a townhouse that was built in 01/02. I am in the process of finishing the basement into two rooms, laundry and family. In the laundry I would like to put vinyl tile, and in the family room I would like to place carpet and tile around the bar. What type of vapor barrier if needed would you place down? would you raise the floor. Would you just place a carpet pad down? Just want to get ideas.. Thanks....
jscholl411 is offline   Reply With Quote
Old 09-18-2006, 05:57 PM   #2
Master Craftsman
Big Dave's Avatar
In my area they just lay the carpet and pad on top of the concrete. Tile is stuck directly to concrete and same with vinyl.
Do one thing at a time, do it well, then move on.
www.bigdaveswoodworks.com
Big Dave is offline   Reply With Quote
Old 09-18-2006, 06:03 PM   #3
World famous jerk.
You may already have a vapor barrier under the concrete. If so, you don't want to add one on top. A double vapor barrier is a big no-no.
The test for a possible vapor barrier is to duct tape a 2' square (roughly) piece of poly plastic onto the concrete, completely sealing it to the concrete. Leave it for a few days. Peel it up and look for water droplets on the underside. If water droplets, you need a vapor barrier. If none, you don't.
mdshunk is offline   Reply With Quote
Old 09-19-2006, 07:57 AM   #4
Thank you very much. I placed down the test piece of poly last night. I will check it today or tomorrow.....If there is no condesation then dont put a vapor barrier and if there is put one down. Ok thanks for the help......
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Basement Floor Drain amazinlittledevil Plumbing 8 01-04-2007 01:17 PM
waterproof basement floor?? patnshan Remodeling 3 09-07-2006 01:58 PM
Basement floor reno D.RED Flooring 1 06-21-2006 02:20 PM
Uneven\Buldging Cement Basement Floor SSandecki Flooring 5 12-20-2005 05:06 PM
