Old 01-22-2013, 09:18 PM   #1
Basement floor
Had an open drain in basement floor. Laminate flooring was put down with a moisture barrier underneath. Found an area where it bubbled in between some of the flooring there was mold. Pulled the flooring up and underneath moisture barrier it is all wet. What can be done? Basement was never wet.
Angela M is offline   Reply With Quote
Old 01-22-2013, 09:37 PM   #2
Tileguy
JazMan's Avatar
Basement floor
Hi Angela, welcome
You've got a wet basement or a leak. It may not have appeared damp before, but now it's covered and the moisture can't evaporate easily.
Wet floors, no place for wood products.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
laminate flooring over basement door in floor... tonyg1 Flooring 0 08-18-2011 03:35 PM
Leveling a Basement Cement floor Tinkertom67 Flooring 0 08-14-2011 01:49 PM
Vapor barrier & insulation for basement floor dvsanfor Flooring 5 09-26-2010 11:01 PM
Finishing a cement basement floor with carpet and tile - no subfloor? vseven Flooring 2 09-21-2010 10:41 AM
Basement floor reno D.RED Flooring 1 06-21-2006 03:20 PM
