Basement Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 07-21-2012, 10:15 AM   #1
basement floor
what can i use to seal my basement floor to keep water from coming up through it?
patcarter is offline   Reply With Quote
Old 07-21-2012, 03:50 PM   #2
Rewards Points: 264
I believe they make sealers for basement floors and walls. It would also be a good idea to keep gutter clean and make sure the down spouts are running away from the homes foundation.
Awoodfloorguy is offline   Reply With Quote
Old 07-21-2012, 04:32 PM   #3
Civil Engineer
Rewards Points: 4,782
If water is coming up through the basement floor, that indicates that the groundwater level is higher than the basement floor. If you were somehow successful in sealing the floor and preventing water from coming up, the floor would almost certainly buckle. This is because every inch of water is equal to approximately 5 pounds per square foot of pressure, and your basement floor is almost certainly thin, unreinforced concrete not designed to handle any uplift pressure.
You need to determine exactly why you are getting water coming up through your floor, and correct the problem by dropping the water table. Sealing your basement floor would almost certainly create far greater problems than you currently have.
Old 07-22-2012, 07:39 AM   #4
I just went through this issue. I found on line some products the swear that they do this, but I wasn't 100% sold on them. But I had water coming in from underneath every wall and through some small cracks in floor. So instead I went with the more expensive root and had the entire basement dug out. Weeping tile redone with the Blue Skin applied. It's a water proof membrane. I also put in a new sump pit that is 4 ft deep. This way the water table is kept below the footings of the house and water can't wick up the concrete. Had a few rain storms and nothing yet except water from the roof getting behind the brick. Lots of money and LOTS of work but it's really the only way to stop water. Keep it away from the house.
TBayDave is offline   Reply With Quote
laminate flooring over basement door in floor... tonyg1 Flooring 0 08-18-2011 02:35 PM
Leveling a Basement Cement floor Tinkertom67 Flooring 0 08-14-2011 12:49 PM
Vapor barrier & insulation for basement floor dvsanfor Flooring 5 09-26-2010 10:01 PM
Finishing a cement basement floor with carpet and tile - no subfloor? vseven Flooring 2 09-21-2010 09:41 AM
Basement floor reno D.RED Flooring 1 06-21-2006 02:20 PM
