Basement Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 02-07-2012, 07:26 PM   #1
basement floor
I am planning to finish my basement. I live on the south shore long island, with a high water table. House is a 1930 cinder block foundation. There is no flooding, but is definitely damp. I get mold if cardboard is against the wall or floor.
I am going to have the walls and rim joist sprayed with 2" of foam.
What about the floor? I only have a 6 1/2' ceiling height, and rather not spend the money for foam board and plywood.
Also, if i don't insulate the floor what will prevent mold from growing on the sheetrock walls from the ground up?
Any info would be greatly appreciated.
sharp is offline   Reply With Quote
Old 02-07-2012, 07:44 PM   #2
Rewards Points: 13,300
And why are you going to try and finish this floor?
May want to check into what it's going to cost before making plans to finish it.
Not a diy job if the plan is to have it come out level and flat.
The slab will have to be about 4" thick so your only going to have about 6' of room left.
There's no room to install a door, can not be concidered a room when it's sold.
For any hope of this plan working out you need to do a whole lot of work outside before doing anything inside.
Water proofing the foundation, french drain, making sure there's working gutters, no mulch piled up againt the foundation, grade sloping away from the foundation.
Old 02-07-2012, 08:07 PM   #3
The floor is a concrete slab, fairly level... plan on carpeting. The gutters are fine. I have good sloping away from the foundation. Not interested in resale value, only additional space for kids and their friends.
Old 02-07-2012, 08:12 PM   #4
No flooring or wall covering will work until you get the moisture under control.
Most of water control is done outside not inside.
Old 02-07-2012, 08:17 PM   #5
so the claim from the insulators that the 2" closed spray foam will produce a moisture barrier is false?
Old 02-07-2012, 08:24 PM   #6
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 56
Yes....
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 02-11-2012, 12:06 AM   #7
Rewards Points: 56
Why do all your replies sound like an ad?
There was spam that has been removed.
Old 02-11-2012, 04:46 AM   #8
2lb Spray Foam
Originally Posted by rusty baker View Post
Yes....
2lb spray foam is a air barrier at 1" thick and a vapor retarder at 2"thick.
acrylic55 is offline   Reply With Quote
laminate flooring over basement door in floor... tonyg1 Flooring 0 08-18-2011 03:35 PM
Leveling a Basement Cement floor Tinkertom67 Flooring 0 08-14-2011 01:49 PM
Vapor barrier & insulation for basement floor dvsanfor Flooring 5 09-26-2010 11:01 PM
Finishing a cement basement floor with carpet and tile - no subfloor? vseven Flooring 2 09-21-2010 10:41 AM
Basement floor reno D.RED Flooring 1 06-21-2006 03:20 PM
