Basement Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 11-28-2011, 12:23 AM   #1
Green Hat
Rewards Points: 170
Basement floor
Gents, I am looking into putting some flooring in on the other side of my basement that is almost finished. I finished up the bathroom, and instead of using ceramic tile, I went with the stick down/groutable 12 x 12 laminate tiles in a diamond pattern.
Poured floor leveler into the bathroom to help get things right after having to concrete over plumbing rough in, then used an adhesive enhancer for concrete floors, stuck them, rolled them, then grouted them. Turned out great.
I am wondering, first of all.........does anyone think that I may run into issues in the future with a flooring setup like this? I am considering doing the same thing in the rec room/bar area of my basement and want to make sure that its don't right prior to making that investment.
Thanks!
Mills314 is offline   Reply With Quote
Old 11-28-2011, 07:27 AM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 12
First thing is to moisture test.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
laminate flooring over basement door in floor... tonyg1 Flooring 0 08-18-2011 03:35 PM
Leveling a Basement Cement floor Tinkertom67 Flooring 0 08-14-2011 01:49 PM
Vapor barrier & insulation for basement floor dvsanfor Flooring 5 09-26-2010 11:01 PM
Finishing a cement basement floor with carpet and tile - no subfloor? vseven Flooring 2 09-21-2010 10:41 AM
Basement floor reno D.RED Flooring 1 06-21-2006 03:20 PM
