Basement Carpeting Choice - Flooring - DIY Chatroom Home Improvement Forum
Old 02-15-2012, 04:18 PM   #1
Rewards Points: 18
We had some water damage to our basement floor, asbestos tile yippee. I would like to use carpet tiles over the asbestos and leave it alone. Iíve read that Olefin is a good choice because it doesnít absorb moisture as much as some other types. Can anyone recommend a good brand or if there is a better material out there? Also should we put down some sort of membrane or sealer on the floor before the carpet tile ? The basement has been waterproofed. It gets not necessarily damp down there in the spring but there will be increased moisture, we intend to have the dehumidifier running. Thanks!
section319 is offline   Reply With Quote
Old 02-15-2012, 04:58 PM   #2
Rewards Points: 13,458
Those tiles will do no one any harm unless someone starts cutting them up.
Until you get that moisture under control I'd never suggest any form of carpet.
Over insulate basement? braverichard Building & Construction 26 06-22-2010 08:26 PM
Thoughts and ideas basement finishing and HVAC creamaster HVAC 1 03-10-2010 07:46 PM
basement subpanel suggestions/advice desired ScottsName Electrical 4 02-26-2009 06:38 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 09:09 AM
