Basement Bathroom Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 07-21-2014, 11:50 PM   #1
Basement Bathroom floor
Hello,
I just finished most of my basement using DeltaFL on the slab, covered by 3/4" OSB, tapcon'd in place. We then had carpet installed on the OSB. I'm now moving on to finishing the basement bathroom. I put the DeltaFL over the floor in the bathroom space as well, but would now like to tile the floor in there.
My plan was to put 7/16 OSB tapcon'd down, then Ditra, then the tile. That thickness should keep me pretty even with the carpet in the hall. I put down the OSB and then realized that I hadn't been considering the slope of the floor. So now I have a few options that I'm knocking around:
- Leave the OSB in place, level the floor with SLC/thinset on top of the OSB, then Ditra, then tile. This would raise the floor at the threshold to the hallway by around 3/4"-1", making a decent lip up into the bathroom.
- Leave the OSB in place, and only level the floor in the 5' dimension, letting it still slope away from the tub toward the hall/door. This would make a smaller transition (if any) between the bathroom tile and the carpet. But I would then have to deal with my toilet and vanity needing to be shimmed to be level.
- Tear out the OSB, and do what on top of the DeltaFL to make the thinnest level, sound, subfloor for the tile?
Removing the DeltaFL is not an option.
Thanks for any suggestions!
Jason
gottjas is offline   Reply With Quote
Old 07-22-2014, 01:04 AM   #2
Tileguy
JazMan's Avatar
Rewards Points: 236
Jason,
If you want ceramic tile in that bathroom, removing the Delta FL is the only option.
I've got some bad news for you, sorry. Ceramic tiles is not one of the types of flooring you can install over a Delta FL system. Did someone tell you different?
Jaz
JazMan is online now   Reply With Quote
Columbus Ohio Basement Full Bathroom -Post-Construction Compliance Hermi14 Plumbing 5 03-12-2013 08:11 PM
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
Roughed In Bathroom - Basement mchughsy Plumbing 2 04-24-2011 11:40 PM
Finishing a cement basement floor with carpet and tile - no subfloor? vseven Flooring 2 09-21-2010 10:41 AM
New drains under the basement floor, guidance needed mason Plumbing 6 01-10-2009 05:58 PM
