Basement Bathroom Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 09-12-2011, 06:56 PM   #1
Basement bathroom floor
About to finish basement, saving best for last...1/2 bathroom. I installed Platon's plastic sub-floor system http://www.certainteed.com/resources/FND_Platon-Flooring-Protector-Brochure_40-96-02C%20.pdf below OSB subfloor to raise off cold concrete, I hired out the carpet installation. Deciding what to do in bathroom. I want tile in bathroom and I want to raise off cold concrete also but Platon literature doesn't say tile as choice of flooring. I noticed in some areas with carpet that subfloor creeks a little meaning anchors I possibly installed improperly (spun in hole) or didn't fasten with enough. Are there any concerns with this product in bathroom as long as I intall 3/4 inch OSB fastened with lots of Tapcon anchors. I don't want the floor "moving" since it will lead to cracked grout and/or tile. Also, can I mortar directly over OSB? It's a 1/2 bath so shouldn't have excessive moisture so is cement board even necessary? Will wet mortar cause issues with OSB? Thank you in advance for your help.
8roty is offline   Reply With Quote
Old 09-12-2011, 07:13 PM   #2
DIY staff
Rewards Points: 7,174
Tile should never be attached to OSB --also no wood should ever be attached directly to a concrete floor
The moisture will cause failure---
However setting tile directly on a concrete floor is the ideal surface.
Old 09-12-2011, 07:31 PM   #3
Thanks for the reply. I installed the Platon underlaymet to raise OSB off concrete. I was hoping to also install in bathroom. Tile directly on concrete = cold tile = cold toes.
Old 09-12-2011, 07:36 PM   #4
DIY staff
Tile failure will hurt toes---Better cold toes than the alternative.
Old 09-12-2011, 07:36 PM   #5
Thanks for the reply. I'll plan on 1/4 inch cement board over OSB if I decide to use Platon underlayment. Are there any acceptable wood subfloors for mortar application?
Old 09-12-2011, 07:57 PM   #6
DIY staff
Cork--comes in rolls and can be laid on top of the concrete and under the tile---
used in concrete apartment buildings for sound control between floors.
Old 09-12-2011, 07:59 PM   #7
DIY staff
Wood is a bad choice under tile as wood expands and contracts at a different rate than tile--
That's why the 1/4" backer board or Ditra is used,
Old 09-12-2011, 08:00 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Can ceramic tiles be installed over a platon upgrade? If it is an upgrade.
Old 09-12-2011, 11:39 PM   #9
I am considering the Ditra underlayment instead of the 1/4inch backerboard. Instructions on FlexBond mortar I purchased says do not bond directly to OSB panels. Ditra installation calls for thin-set mortar to bond the underside of the Ditra underlayment, one substrate option being OSB. Is there a specific mortar that is acceptable for OSB bonding?
Old 09-13-2011, 10:25 AM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
That statement is referring to bonding tiles directly to OSB. Underlayments are a different story.
Schluter Systems (DITRA) is in bed with a thinset manufacturer and they have developed a product called "DITRA Set" which is now their recommendation for use with DITRA but it is not necessary. And DITRA Set may not be suitable for use with OSB. The Schluter website has all of the instructions there.
Any modified thinset can be used to bond DITRA to OSB, it is done every day.
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
Roughed In Bathroom - Basement mchughsy Plumbing 2 04-24-2011 10:40 PM
Finishing a cement basement floor with carpet and tile - no subfloor? vseven Flooring 2 09-21-2010 09:41 AM
New drains under the basement floor, guidance needed mason Plumbing 6 01-10-2009 04:58 PM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
