Baseboards Around Fireplace Help - Flooring - DIY Chatroom Home Improvement Forum
Old 03-16-2014, 12:57 AM   #1
Baseboards around fireplace help
I was curious if this would be the proper way to install baseboards and connect it to the trim around the brick behind my fireplace. The pic attached I have the pieces just sitting there, not attached at all yet.
What would in your opinion be the best option here?
apmarlow is offline   Reply With Quote
Old 03-16-2014, 12:58 AM   #2
Sorry the pic is upside down.
Old 03-16-2014, 05:40 AM   #3
An old Tradesmen
Rewards Points: 6,148
Rotated it for you.
Old 03-16-2014, 05:53 AM   #4
Rewards Points: 12,886
Going to be up to you what looks best.
The base does not need to run up on the bricked area like that, it can stop at that bottom step.
Which can be done by making it shorter so it comes out even with the top of the brick, or be ripped and cut with a jig saw so just the top part runs over the bottom step.
Remodelling den and fireplace doors coyote97 Building & Construction 0 11-22-2013 01:01 AM
Trying to troubleshoot a gas fireplace, need help glenh Appliances 3 11-03-2013 07:48 AM
Fireplace reno help, wood to gas fireplace jsunsun Building & Construction 4 01-15-2013 09:09 PM
How to go about replacing fireplace surround? NewHomeDIYGuy Remodeling 9 01-26-2012 10:56 PM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 11:07 PM
