Baseboard Material Question - Flooring - DIY Chatroom Home Improvement Forum
Old 03-03-2013, 11:56 AM   #1
Baseboard material question
Been looking to replace all my baseboards and I'm seeing they're made of solid wood, MDF type stuff and PVC. Is one better than the other for my needs and situation. This will be my first baseboard project. I have plaster walls and wood floors and I live in So. Cal. if this info helps. Thanks
TW200 is offline   Reply With Quote
Old 03-03-2013, 12:18 PM   #2
Rewards Points: 12,886
Use real wood, it's cheaper if you buy it already primed in the contractors packs.
The cheap plastic stuff likes to melt when trying to cut it.
The MDF dents to easy and will be distroyed if it gets wet.
oh'mike (03-03-2013)
Old 03-03-2013, 12:52 PM   #3
DIY staff
Rewards Points: 7,174
I second that---real wood----Poplar is very nice to work with----do check and see if you have a hardwood/millwork place near by---often they have nice profiles at the price of ordinary Big Box styles.
Also--buy the longest lengths that work for you---the fewer splices the better----
Old 03-03-2013, 12:56 PM   #4
Learn how to cope your inside corners.
Better look, no gaps, seams will not open up later.
When you do have to splice two pieces together make sure to cut where they over lap at a 45 deg.
Old 03-03-2013, 03:46 PM   #5
Thanks for the quick, helpful replies.
baseboard / tile / carpet questions firstimereno Flooring 10 08-20-2012 02:14 AM
Baseboard Question polar5554 Flooring 2 02-25-2008 02:08 PM
Baseboard Question in New Home BusterPercheron Building & Construction 5 11-20-2006 07:16 AM
Question re: fiber-cement soffit material MichaelinOmaha Carpentry 4 10-12-2006 08:30 PM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 08:41 PM
