Baseboard Install Over Laminate Flooring? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-06-2010, 09:08 AM   #1
Baseboard install over Laminate flooring?
This may be a stupid question, but the instructions for PERGO seem to indicate that I need to leave a 1/4 inch expansion joint between the baseboard and flooring....am I reading this wrong?
Oxymoron is offline   Reply With Quote
Old 08-06-2010, 02:10 PM   #2
Handyman
Rewards Points: 512
No. The flooring needs 1/4" around the perimeter to allow it to expand and contract (float) If your baseboard is high enough to allow you to install the laminate underneath, then you can do that (depending on how thick the base of the baseboard is. Usual installation requires installing quarter-round after the floor is finished. This provides the ability for the floor to move and eliminates future gaps. Just be sure to nail the quarter-round into the wall, through the bb....not the floor.
canadaclub is offline   Reply With Quote
Old 08-06-2010, 08:18 PM   #3
I am finishing a basement, so there was no existing baseboard.....so just sit the basboard flush on top of the pergo?
Old 08-07-2010, 06:50 AM   #4
Handyman
Rewards Points: 512
yep, but not too tight
Strange engineered wood flooring install in Philippines (pics) Flt_Simulation Flooring 7 10-05-2009 10:00 AM
laminate flooring on top of tile newhomeowner808 Flooring 3 09-19-2009 08:34 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 11:34 AM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 09:49 PM
Peninsula install on Laminate flooring? mcaanda Building & Construction 1 05-22-2008 01:01 AM
