Originally Posted by Allyson
1. Is it OK to mix a streamline baseboard style when all my other millwork is of the colonial type? There is not a whole lot of other millwork.
that's probably just a stylistic decision, but if you're trying to be cost-conscious I'm not sure I see the advantage in switching styles if molding is already in place, especially if swicthing to a dissimilar style that the rest of your trimwork.
Which of the 3 options sound the best?
is the rest of the colonial trim you mentioned painted white? if so, then from a cost-savings standpoint, I'd paint the base white to match
3. If I paint the baseboards do I need to use an oil based primer followed by paint. Should I use flat or semi gloss paint?
if the baseboards have already been stained, probably with oil, then I'd use a good oil-based primer like Kilz, and then mop it with white paint after it's dried. Do not use flat on baseboards because it will most easily show marks from shoes and so forth. the glossier the paint, the harder and more durable the surface will be.
