Baseboard - Flooring - DIY Chatroom Home Improvement Forum
Old 08-18-2011, 05:47 PM   #1
Baseboard
Is it possible to install new base board over old base board that cannot be removed with out damaging floor ?
show me is offline   Reply With Quote
Old 08-18-2011, 05:56 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 124
How would removing the old damage the floor.?
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 08-18-2011, 06:15 PM   #3
m1951mm's Avatar
If you add new baseboard over the existing base, you will have a big gap at the top to which you would have to caulk to.
Why would removing the old base harm your floor?? Give details as to how it is now.
Bad choice to add new over existing.
To remove the old, run a utility knife at the caulk joint first!! Then use a 5 in 1 tool down, gently pulling the base from the wall. Once you get started you will be able to tell where the nails are. When pressing your tool, press it to the bottom side of the baseboard, not upwards into the drywall.
At the bottom again if there is a caulk joint, now here I would use a more flexible knife to get it to lay more flat on the floor. Are you working with hardwood?? vinyl?? what is the flooring you are working with? That really should have been my first question.
What is the existing flooring, then better info to come
m1951mm is offline   Reply With Quote
The Following User Says Thank You to m1951mm For This Useful Post:
oh'mike (08-18-2011)
Old 08-18-2011, 07:09 PM   #4
DIY staff
Rewards Points: 7,174
Good tip on using the painters tool to remove the trim!
Once the nails can be located--place the painters tool on top of the nail and hit sharply with a hammer--that will pull the nail right out of the board.
Old 08-18-2011, 07:17 PM   #5
MikeKy55's Avatar
Rewards Points: 254
It may not be the best way, but I have always located the nails and drove them on through the baseboard with a nail set. That way the baseboard falls off.
MikeKy55 is offline   Reply With Quote
Old 08-20-2011, 10:16 AM   #6
Tile with Style
BlueStoneFloors's Avatar
I'm guessing that you're referring to baseboard that has the tile brought up to it instead of sitting on top of the tile? If that's the case there are options-like quarter round trim- besides pulling the baseboard. More info and some pics would be helpful
BlueStoneFloors is offline   Reply With Quote
Old 08-20-2011, 11:17 AM   #7
Rewards Points: 124
Looks like a "drive by poster" . Haven't been back since they posted the question.
Old 08-20-2011, 12:20 PM   #8
Tile with Style
Flooring installer/comedian Rusty?
...yes I'm posting needlessly, need to get enough to unlock private msg...
Hell is 8 months of nothing but slate work...
Old 08-20-2011, 03:19 PM   #9
Rewards Points: 124
I have been accused of having an odd sense of humor.
Old 08-20-2011, 04:08 PM   #10
DIY staff
I usually get your humor right off--but I've got an odd sense of humor too.
Old 08-20-2011, 04:21 PM   #11
Rewards Points: 124
I have a 15 year old with the same sense of humor. We drive his mother nuts.
Problem with 240V Elect Baseboard Heater JRHP Electrical 4 10-04-2010 09:30 AM
Laminate flooring / baseboard gap question willy0314 Flooring 0 08-07-2010 09:48 PM
Installing some baseboard across 2 different floor types? BigJohnny Building & Construction 9 08-03-2010 11:41 AM
Partial hydronic baseboard to radient floor conversion Jeepsail HVAC 4 01-17-2010 04:47 PM
Baseboard dilema Allyson Flooring 5 09-04-2009 08:30 AM
