Base Moulding Vs. Bullnose Tile Surround - Flooring - DIY Chatroom Home Improvement Forum
Old 11-08-2011, 03:10 PM   #1
Base Moulding vs. Bullnose Tile Surround
Hi All,
I hope I'm using the correct terms here but I am trying to decide between using base moulding or bullnose porcelain tile 3" by 12" pieces for the bathroom surround. Any suggestions? The floor I just installed is 12 x 12 porcelain tile.
If I do go with the porcelain tile, to save money could I just buy a case of tiles and do two 3" by 12" cuts so that I get a polished side on both pieces?
Lastly, what should I use as adhesive for the tile if I go that route? Will construction adhesive work, with grout to finish it off?
sullijos is offline   Reply With Quote
Old 11-08-2011, 05:00 PM   #2
DIY staff
Rewards Points: 7,174
I like a tile baseboard in the right room. It's a look. So you must be the judge.
As to slicing up tile for the base---It usually looks bad. Most porcelain tile edges cant be polished
and those that can require tooling so expensive that only full time granite installers can afford it.
Simply buy bull nose and be done.---Mike---
Old 11-09-2011, 09:14 AM   #3
Thanks Mike, that was the way I was leaning. I've seen on websites that mastic is good for installing the tile trim. Will construction adhesive work just as well? Obviously, I will grout after.
Old 11-09-2011, 11:34 AM   #4
liscenced electrician
Rewards Points: 538
I bullnose my own tile but only some can be done. Mainly thru body porcelain and travertine. I use a diamond wheel for a 4" grinder and a polishing kit from harbor freight. Works great on this highly polished thru body porcelain that I've been using all over my house.
Doesn't work very well on granite. Granite just doesn't polish easily for a diy person
jimmy21 is offline   Reply With Quote
Old 11-09-2011, 11:34 AM   #5
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
Baseboard?
The thinset you used on the floor tiles would be your best bet. Mastic would be second choice, acceptable in a non-wet area. I wouldn't use construction adhesive.
Edited to add: Actually I have used construction adhesive for tiles. When we moved into this house we had several loose kitchen counter tiles. I just used the adhesive I had on hand because I thought replacing the counter top was near the top of our to-do list.
It didn't hold.
And it is still on our to-do list.
Old 11-09-2011, 05:30 PM   #6
DIY staff
Actually,PL premium works well for base board tiles---Thinset is cheaper and easier to clean up---so the choice is yours.
Blondesense (11-10-2011)
Old 11-10-2011, 10:43 AM   #7
Thanks for all of the helpful info! This site has been an excellent resource for my bathroom project.
I was told by the flooring specialist at Home Depot to use mastic for the baseboard 3 x 12" tile. I cut the tiles as necessary so that the grout lines would all line up and I managed to get all the pieces up with 1/8" spacers off the floor. My question is, how long should I wait until I grout? I did not apply the mastic thickly in any particular spot, but I don't want to get over-aggresive and grout when the mastic hasn't dried.
Old 11-10-2011, 11:24 AM   #8
Rewards Points: 538
Usually wait overnight. You could do it immediately but there is a chance you might knock them out of place.
Slate Tile Fell Off My New Tub Surround kiziah Remodeling 10 06-24-2011 09:48 AM
straight ceramic tile but crooked base cabinet robismyname Flooring 2 04-05-2011 10:57 AM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
remove/replace tile over mud base jfm617 Flooring 1 07-07-2007 07:38 AM
Tile a shower base? always something Flooring 6 03-19-2007 10:58 AM
