Old 04-08-2008, 10:47 PM   #1
base molding and carpet
i didnt leave a gap between base molding and plywood floor when i installed the molding will this be a problem when carpet is installed?
doc70 is offline   Reply With Quote
Old 04-09-2008, 07:17 AM   #2
You should have left room for the carpet to be tucked under the baseboard. Normally 1/2". If berber carpet and heavy foam (8 pound) 3/4".
bayoudonnie is offline   Reply With Quote
Old 04-09-2008, 12:33 PM   #3
Boz
Gus
Boz's Avatar
Typically 1/4-1/2 makes trimming in the carpet a little easier, but it is not nessecary. If you are having the carpet professionally installed it should pose no problem at all.
Boz is offline   Reply With Quote
Painting floor molding with existing carpeting jscott1206 Painting 6 11-08-2008 04:43 PM
Joining carpet and ceramic tile rooms TedT Flooring 10 05-21-2008 09:25 PM
paint or carpet stringers sandyg General Discussion 2 12-23-2007 01:13 AM
Base molding or carpet first??? Dan N Flooring 5 02-01-2007 09:29 AM
