-   -   base molding and carpet (http://www.diychatroom.com/f5/base-molding-carpet-19680/)
doc70 04-08-2008 09:47 PM
i didnt leave a gap between base molding and plywood floor when i installed the molding will this be a problem when carpet is installed?
bayoudonnie 04-09-2008 06:17 AM
You should have left room for the carpet to be tucked under the baseboard. Normally 1/2". If berber carpet and heavy foam (8 pound) 3/4".
Boz 04-09-2008 11:33 AM
Typically 1/4-1/2 makes trimming in the carpet a little easier, but it is not nessecary. If you are having the carpet professionally installed it should pose no problem at all.
