Base Cove Or Floor? - Flooring - DIY Chatroom Home Improvement Forum
Old 02-28-2008, 08:48 PM   #1
Base Cove or floor?
Which is best to lay first the base cove or the floor? also..does the grout on the floor have to be staingard? or just sealed?
Also...does anyone have photos of a shower ceiling tiled? how difficult is it to do, i dont know how i would keep it up until it dries..? is it even a good idea. ?
Thank you..
Demochick is offline   Reply With Quote
Old 02-28-2008, 10:26 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 388
Hi Chick,
Install the floor tile then set the base over it leaving a gap for grout or caulk.
Are you just adding tile to the ceiling or building an entire shower? Actually tile sticks to ceiling just fine. It kinda sucks on and stays, unlike installing on some wall aplications where it wants to slide if not supported and stacked. http://picasaweb.google.com/tile4you...bByTile4YouInc
Jaz
Old 02-29-2008, 06:05 AM   #3
thanks so much, yes we are tiling the entire shower.
Old 02-29-2008, 11:57 AM   #4
Tileguy
JazMan's Avatar
Rewards Points: 388
If this is your first tile project, good luck. Building a shower correctly is the most difficult tile project you could have chosen. Ask questions if you'd like.
Jaz
Old 02-29-2008, 01:15 PM   #5
Tile Contractor
Bill_Vincent's Avatar
Use a non-sag lightweight thinset and you can pretty much put the tile in place, press it in, and forget about it. The non-sag has alot more "grab" to it than most thinsets. examples would be Laticrete's 255, Mapei's Ultralite, and Custom's Megalite. All three good products.
As for pics, go thru the following album, and you'll find many examples of tiled ceilings:
http://creativeceramicandmarble.com/...&g2_itemId=118
"Whether you think you can, or you think you can't, You're probably right."
http://www.creativeceramicandmarble.com
Bill_Vincent is offline   Reply With Quote
Shower floor base project man General DIY Discussions 2 02-23-2008 07:35 PM
Installing Cove Base countrylife Flooring 3 11-19-2006 12:41 PM
