Base Boards - Flooring - DIY Chatroom Home Improvement Forum
Old 02-26-2011, 03:45 PM   #1
base boards
My hardwood floor where it meets the carpet in the living room is about 1/2 inch higher than the carpet.. If the base boards continue straight and level from hardwood to carpet then the base boards are 1/2 inch above the carpet.
Brent G is offline   Reply With Quote
Old 02-26-2011, 04:12 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Brent, Welcome to the forum
I don't get it 'the floor is about 1/2" higher than the carpet' ?
Can you post a Pic?
Disclaimer
& Stay Safe
.....Bob Lavery
Old 03-01-2011, 12:46 AM   #3
Master of none
You have two choices
Depending how much baseboard you are putting down, you can rip a half inch off the basboard that goes on the higher floor, or add a half inch to the bottom of the board that goes on the lower floor. I have done both. If you do the second, you need to fill and sand the joint, then paint it so it doesn't show. This could be a lot of work!
Good luck
handy andy is offline   Reply With Quote
Sink base vs regular base cabinets... J187 Kitchen & Bath Remodeling 3 12-03-2010 07:40 AM
painting trim and base boards fabian Painting 19 10-10-2010 01:48 AM
how to nail base cap of baseboard molding conradA Flooring 3 06-23-2010 11:57 AM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
carpet and base boards juanitagant Carpentry 4 05-21-2009 12:32 PM
