Bamboo Wood Floor "Toast" - Flooring - DIY Chatroom Home Improvement Forum
Old 09-21-2011, 05:05 PM   #1
Bamboo wood floor "Toast"
There is another recent post about bamboo flooring. Coincidentally, I'm also thinking of installing bamboo, Toast from Home Depot.
The subflooring is mostly particle board, 5/8", laid on top of a black fabric on top of a wood floor (not sure how thick). It's not glued down.
There is a big curve in the floor, due to the old building settling. I would estimate a 3" rise over 4-5' distance.
I would lay the flooring in the direction perpendicular to the curve, in other words, the planks would look like a bridge across the gap.
What is recommended for a situation like this? Should the floor be glued down, or should it be floating?
Thanks for any advice.
Fredericch
fredericch is offline   Reply With Quote
Old 09-21-2011, 06:21 PM   #2
woodman58's Avatar
If your floor has a 3" dip in 4'-5' you need to take the floor down to the joist and fix it. If you install any wood floor over partical board (PB) it will have to be a floating installation. You can not nail a wood floor over PB. Nails do not hold. You can not glue wood over PB. The moisture in the glue will make the PB swell and will eventually work your floor loose. I would get rid of the partical board.
I LOVE THE SMELL OF SAWDUST IN THE MORNING!
woodman58 is offline   Reply With Quote
The Following User Says Thank You to woodman58 For This Useful Post:
Floor Doc (09-22-2011)
Tags
bamboo , curved , floor
Sister joist, replace wood bean, what wood grain? jpcada Building & Construction 14 04-13-2010 07:46 AM
Staining Wood - When to use wood filler markronz Carpentry 8 03-04-2010 07:15 PM
Vent Noise - Rubbing Wood; Seeking Advice steveo_1978 Plumbing 4 01-22-2010 10:26 PM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 04:30 AM
DAP caulking question n0c7 Painting 16 10-31-2008 11:31 PM
