Bamboo Vs Engineered Vs Hardwood - Flooring - DIY Chatroom Home Improvement Forum
Old 11-01-2011, 09:33 PM   #1
Bamboo vs Engineered vs Hardwood
I am looking for advice on which type of flooring would be the best for a foyer,kitchen, 1/2 bath and den/office. I have 5 kids and 2 dogs, so there will be a lot of traffic and potential and strong likelihood for scratches and dings. ( I have pretty much ruled out solid hardwood for that reason). Is there anything out there that has a WOW factor? Thanks in advance for any and all input.
katetate is offline   Reply With Quote
Old 11-02-2011, 02:40 AM   #2
43 years in construction
Arkitexas's Avatar
Originally Posted by katetate View Post
... and strong likelihood for scratches and dings. ( I have pretty much ruled out solid hardwood for that reason)....
Then you should probably rule out bamboo too. Bamboo is softer than hardwood. By hardwood I mean true hardwoods such as white oak, red oak, maple, walnut, cherry, etc. This does not include softwoods such as pine, cedar, bamboo, redwood, etc. I raised two boys and two girls in a house with oak hardwood floors without kid damage. The biggest dents in my floor were from my moving an upright piano having small wheels. In the long run, large dogs are hard on any kind of wood floor. Out of the three surfaces you mentioned, I guess you are only left with laminate flooring.
Laminate flooring isn't the best in kitchens or other potentially wet areas. Liquids easily penetrate the joints and can mold, mildew, or rot beneath. That said, many people still install laminate flooring in such areas. Kitchen, bath, entry foyer, and laundry areas are most compatible with ceramic tile or sheet vinyl surfaces. Laminates work well in other areas of the home assuming the subfloor is flat.
Rick
Arkitexas is offline   Reply With Quote
The Following 2 Users Say Thank You to Arkitexas For This Useful Post:
logluvr (11-08-2011), rusty baker (11-02-2011)
Old 11-02-2011, 07:03 AM   #3
Sephora's Avatar
Rewards Points: 150
Ditto Rick...Bamboo is softer...
Sephora is offline   Reply With Quote
Old 11-02-2011, 07:07 AM   #4
I know that I do not want laminate. I am confused, because from what I have been told by a few flooring retailers, the "stranded" bamboo is by far one of the hardest woods out there. I would like to know if thats true. I know that bamboo itself is soft, so that would not work. Any one have any experience with the stranded bamboo? I keep going back and forth between engineered hardwood and bamboo (stranded), and then hardwood too! I need to make a decision ASAP. I want unbiased experiences from real people. Again, thanks in advance for any and all input.
Kate
Old 11-02-2011, 07:19 AM   #5
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 112
One clarification, bamboo is not wood, it is grass. That said, wood and/or laminate does not belong in any kitchen. Although hardwood will stand up to moisture better than laminate, neither should be used in moisture prone areas. Remember, if laminate gets scratched, which it can, it will always be scratched. Hardwood can be refinished.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 11-02-2011, 07:54 AM   #6
Too Short? Cut it Again!
Not sure what hardness tests the guys are looking at but bamboo tests out harder than most hardwoods. And it is better adapted to moisture and humidity changes. You can get the real stuff, not box store junk, in either conventional planks that get nailed like hardwood or as engineered flooring.
Now then, composite strand bamboo is another story. It is beautiful and harder than conventional bamboo or hardwood flooring. It is used in industrial and commercial applications when extreme durability and great looks are called for.
Cork is your other option for a kitchen and one with kids and pets. It is naturally resilient and does not have to look institutional.
Here is one source for all. There are others if you search on line.
http://www.duro-design.com/index.cfm...mboo-flooring/
Old 11-02-2011, 08:23 AM   #7
JohninSC is offline   Reply With Quote
Old 11-02-2011, 08:26 AM   #8
I have Tiger wood in my house but we don't have kids, just 2 yorkies.
Old 11-02-2011, 09:24 AM   #9
Sephora's Avatar
Rewards Points: 150
I can tell you that we just ripped up Pergo Laminate Wood in our kitchen. Our problem was we lost the finish. It was fine in the beginning but I grew to hate it after it lost it's luster...we used regular cleaning products on it was our problem. I guess if we took care of it as we should have (we didn't know we were ruining it) it would be just OK for us to keep.
We are now down to the subfloor and reinforcing to lay down tile.
So I vote for no laminate.
Old 11-02-2011, 09:34 AM   #10
We just installed Yanchi 9mm Strand Woven Bamboo (Janka Hardness: 2820), and it looks great.
hellobritt is offline   Reply With Quote
Old 11-03-2011, 02:38 AM   #11
Rick
I agree with Rick. Laminate flooring isn't for wet areas.
alain33 is offline   Reply With Quote
Old 11-05-2011, 06:27 PM   #12
Strand woven bamboo is extremely hard. One of the hardest made. Twice as hard as Oak. The test for hardness of wood is called the Janka Test. Google (Janka test wood). Try www.academyfloor.com for Janka Test results. Look for a strand woven bamboo with a good finish warranty. Mohawk makes a good one with a Uniclic floating floor system. Real easy product to install.
plowboy is offline   Reply With Quote
Old 11-05-2011, 07:34 PM   #13
Arkitexas's Avatar
Stranded woven bamboo is an engineered flooring product and is harder than virgin oak because all voids are filled with urea formaldehyde resin. It's the resin that's hard not the bamboo. Virgin bamboo and carbonized bamboo are not as hard as oak. If oak was cut into fine strips, impregnated with urea formaldehyde resin in a 1200 psi heated prews press, oak would be equally hard.
In any case oak, bamboo, engineered wood products, as well as wood-backed products, are not good choices for wet areas.
Rick
Old 11-05-2011, 08:02 PM   #14
Rick
Virgin bamboo and carbonized bamboo are BOTH harder than oak! Check the Janka test results.
Old 11-06-2011, 10:13 PM   #15
If you are considering bamboo , Just take your thumbnail ands try to make a crease in it . I don't care how hard they "say" it is , Experience says it is not hard , Second You have Kids dogs etc , I would not recommend hardwood , I am a hardwood pro tacomahardwoodfloors.com I would put tile or vynil or real hardwood and refinish it in ten years , I have seen people that have the kid dog living situation with Brazillian cherry , It got destroyed . Yes you could refinish it , but they scratched and dented it .
tacomahardwood. is offline   Reply With Quote
hardwood on engineered floor? kalpi Flooring 1 09-27-2011 06:32 PM
Installing 3/4" Engineered Hardwood over Particle board New_Floors Flooring 4 01-26-2011 09:23 PM
Dricore and Engineered Hardwood doughboy52 Flooring 0 06-23-2010 08:45 AM
poly on engineered hardwood floor? Constant Improvement Flooring 3 02-03-2009 11:09 AM
can engineered hardwood be a floating floor? smythe01 Flooring 10 07-09-2008 10:16 PM
