Bamboo Flooring Install - Flooring - DIY Chatroom Home Improvement Forum
Old 04-01-2012, 01:56 PM   #1
I plan on purchasing and installing a carbonized stranded bamboo floor. It's manufactured by Morning Star and is 3/8" thick by 3 3/4" wide. This floor is going on a cement floor (Florida slab home) and I'm considering installing as a floating floor. I'm asking for anyone with experience in installing bamboo as described to comment. I know this is one of the hardest floors and was wondering if cutting isa problem? Your ideas and suggestions please. Thank for your input.
joe3534 is offline   Reply With Quote
Old 04-01-2012, 08:37 PM   #2
Rewards Points: 636
i do not think bamboo is that hard as of what i have seen a few years after install. here is a link on species hardness chart. http://www.countyfloors.com/about_janka.html
and i do not do enough to comment on install on concrete on Florida slab
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 04-02-2012, 02:00 PM   #3
wood hobbyist
Joe3534,
I've installed the exact same bamboo flooring in my house glued to the concrete foundation, with no problems. I have to agree with jaydevries that its not the hardest but it looks and works well in our house. Three kids, & two dogs tested for over three years now and no problems. Some suggestions I have for you, I layed my floor out and blue tape numbered them before gluing them down to not slow up a one man show. Work only about two board widths at a time. Start with a new, sharp, fine tooth saw blade for cuts. Have a wet towel to assist clean-up along the way and as you put down a full run use something to weigh down the boards to ensure positive glue aheards to both the wood and floor. I used some 12x12 stepping stones with a towel underneath moving them across as I moved to a new run of board. Remember 1/4" gap on the outside of primeter and to mix up the boxes as you open them for a uniform look. Post some pictures of you work when done. Good luck.
weberus3 is offline   Reply With Quote
Wife wants bamboo flooring. Two dogs pee on floor. Sowak Flooring 44 03-05-2012 05:25 AM
Bamboo Flooring Tinkdles Flooring 1 11-20-2011 10:14 PM
How do I install hardwood flooring to a textured wall cipstrip Flooring 1 09-15-2010 10:50 AM
Bamboo flooring in motorhome sanantoneo Flooring 1 10-27-2008 11:08 AM
Hardwood - engineered vs solid? cbeingessner Flooring 12 05-19-2008 10:37 AM
