Bamboo Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 04-29-2012, 11:41 AM   #1
Bamboo flooring
Right now the interior of my house is all indoor/outdoor carpet even in the kitchen and I hate it. I would like to install Bamboo wood flooring in at least half the house except maybe the bedrooms and bathroom. My house is on a concrete slab and I checked underneath a part of the carpet and it looks like there's concrete backer board as the subfloor. Can I reuse the existing subfloor to put the Bamboo flooring on or will I need to install a new subfloor? I'm not totally sure on the options for how the hardwood floors come in. I know my friend installed hardwood flooring that snaps together in his house. Are there other options of Bamboo flooring besides the kind that snap together?
Christoph006 is offline   Reply With Quote
Old 04-29-2012, 11:47 AM   #2
Too Short? Cut it Again!
I love bamboo flooring and it is harder than domestic hardwoods. Once installed, it is beyond pretty. It is renewable so you get green credits. You can get it in what ever color you want.
Nice, not box store or liquidator bamboo comes in both forms for nailing like hardwood or floating or gluing or floating like other manufactured flooring. This company is my fave and they are great about sending you samples and explaining any questions to your flooring contractor. My folks love the materials and my clients have to.
www.duro-design.com
With any flooring, you have to resolve your subfloor issues but you know that.
Old 04-29-2012, 11:55 AM   #3
Rewards Points: 12,824
Cement tile board should never have been installed directly to a slab floor.
Your going to need a vaper barrier, also concider using engineered flooring not just a laminite.
It's far more stable, can be installed with glued seams to act as a floating floor and can still come with bamboo as the top layer.
Old 06-18-2012, 08:00 PM   #4
What type of product can you put on a new bamboo floor
GailjT is offline   Reply With Quote
Old 06-18-2012, 09:59 PM   #5
Pro
JetSwet's Avatar
Rewards Points: 502
I think joe is correct bamboo not great idea for a slab.
I'm thinking they must have put cement board down as perfection against mosture.
JetSwet is offline   Reply With Quote
Old 06-20-2012, 04:58 PM   #6
I would take up the cement board, lay an underlayment over the slab and then get a floating bamboo floor. Just make sure it is a product that is made to go over concrete.
RhodesHardwood is offline   Reply With Quote
Old 06-22-2012, 07:13 PM   #7
I personally do not like Bamboo. Way to unstable to moisture. I am in Houston and humidity is an issue for us. Solid Bamboo should NEVER be glued to the slab direct. If you do decide to try it...you should do a calcium chloride test on your slab to check the hydro static pressure. I would install it over tar and screeds only on slab. If you choose bamboo use engineered. No worries on a second story though.
Thefloorman is offline   Reply With Quote
The Following User Says Thank You to Thefloorman For This Useful Post:
JetSwet (06-22-2012)
My Bamboo Flooring Experience schraggyj Flooring 3 08-21-2011 06:24 PM
bamboo flooring sueriles Flooring 9 07-11-2011 06:55 AM
Installing Bamboo Flooring with Brad Nailer? aaks38 Flooring 3 11-04-2008 10:11 AM
a few questions about bamboo flooring installation bostonmike Flooring 2 01-19-2008 09:06 PM
what type of nail gun for bamboo flooring? matchley Flooring 4 12-26-2007 04:47 PM
