Bamboo Engineered Flooring/ Expansion Joint - Flooring - DIY Chatroom Home Improvement Forum
Old 04-16-2011, 10:55 AM   #1
Installing a bamboo engineered floor; at the longest length it measures 30 feet, do I need to put in an expansion joint?
Annielaurie is offline   Reply With Quote
Old 04-16-2011, 11:24 AM   #2
woodman58's Avatar
Yes. You need an expansion joint on all wood floors. You should leave 1/2 inch. If you base board will not cover this space, you need to put shoe molding.
woodman58 is offline   Reply With Quote
Tiling over expansion joint - confused jkr77 Flooring 20 04-12-2011 03:56 PM
Laminate flooring without expansion joint Platypus Flooring 7 03-13-2011 10:03 AM
Bamboo Flooring Installation Gap for Expansion rayf01 Flooring 2 10-15-2010 11:19 PM
Strange engineered wood flooring install in Philippines (pics) Flt_Simulation Flooring 7 10-05-2009 09:00 AM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
