Old 12-02-2012, 04:56 PM   #1
allphaser's Avatar
Baking soda carpet odor
I Applied (2) 4 lb. boxes of Arm & Hamer Pure Baking Soda To remove odor from carpeting and padding, I lifted the carpet and applied to top of padding and bottom of carpeting then tried vaccuming after a few hours. Is it ok that some of the baking soda I left. Under the carpet .? By the way I have hardwood flooring that is in bad shape hence why it's carpeted..
Thank all
allphaser is offline   Reply With Quote
Old 12-02-2012, 06:44 PM   #2
Part of the reason that hard woods in bad shape is it's over a dirt floor.
Is there a vaper barrier on the ground in the crawl space.
Was there pets in the house?
Pull the carpet and padding back to see if there's pet stains and odor in the wood it's self. If so your going to have to seal it, may also have to toss and replace the padding at least.
Carpet odor removal baking soda allphaser General Discussion 1 12-03-2012 06:51 PM
Flooring Under Carpet Mstrenke Flooring 4 06-24-2012 06:54 PM
Carpet Flooding and Replacement airjay81 Flooring 1 05-08-2012 01:00 PM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
