Old 01-27-2007, 07:45 PM   #1
Default Is it bad to use mortar to level a floor?
We are about to put down the backerboard in our bathroom so that we can eventually put the new tile on top of that, however our floors are not completely level. The floor height varies +/- 1/8" (1/4 at the extremes). We know we need to level the floor below placing the backer board on it, because the last thing we want is for the backerboard to flex and ultimately cause cracks. Would it be bad to just use normal mortar to level out the floor (the same mortar we were going to use to afix the backer to the floor before screwing it in? We'd like to just use mortar if possible, and have the mortar slightly 'deeper' in some areas. We do have some 'self leveling' compoud, but to be honest.. it makes us nervous. We're afraid that since it's so liquidy, that it will find a crack somewhere and run down under the floor and onto the ceiling downstairs. HELP! * Also, is there a 'max' depth for the mortar?
CB2007 is offline   Reply With Quote
Old 01-27-2007, 10:35 PM   #2
remodeling pro
Do not use mortar, use floor patch. This is not the same as self leveling and is screeded or troweled into the low spots to fill them. Your concern about self leveling is justified, if mixed thin enough to flow properly, it will find any crack or opening to run through.Also, do not use regular mortar to bed the backer board, use thin set. Talk to your tile supplier, he will give you the correct products.
troubleseeker is offline   Reply With Quote
Old 01-27-2007, 11:05 PM   #3
My Parts had a floor in a 200 yr old house that need "flatened" the middle was almost 2" lower than the edges (Jacking wasn't an option) so we use Mortar to level it. It's been 3 years with a floating floor over it and No problems to speak of.
mdlbldrmatt135 is offline   Reply With Quote
Old 08-05-2008, 04:50 PM   #4
Tileguy
You cannot use a patching product to "plane/flatten" the floor then install cement board over that. You need the cement board installed first in a bed of fresh thinset THEN after the cement board is contoured to the subfloor you can plane the surface from there.
Overall Self Levelling Compound would be the path of least resistance. It's a great product but requires some attention to detail. To discourage the use of SLC is a sign of inexperience.
Floating floors have nothing to do with this project and shouldn't even be in the conversation.
Old 10-01-2008, 10:38 AM   #5
Default do you have answer to question below
brian mc tigue is offline   Reply With Quote
More On This Topic
How to Trim Tile
How to Trim Tile by eHow.com
Applying tile to a room can add interest as well as accentuate architectural details. Choosing the right tile for trim is very important and can add the proper finishing touch that makes or breaks a project. Read this article to learn more. Read More »
You love your kitchen floor because of the real tiles laid on it. You like the color, but you like the color even better when the tiles are wet, and they look more vibrant. But read below for some other ways to add some shine to your ceramic or slate... Read More »
I’m Lee, I have a degree in architecture and about ten years experience in the construction field. Today we have been installing a designer counter top and we’re ready to grout it. You just want to buy the grout color of your choice- we’... Read More »
In this segment I'm going to talk to talk to you about how to bounce a ball. As you can see I'm on tile today and it's a little tricky cause it has cracks in it. So I really want to practice right in the middle but if you're on hardwood floor or linoleum... Read More »
Hi! This is Steven Keilholz Flooring on behalf of Expertvillage.com and today I am going to show you the materials you need to install a ceramic floor in your basement. The first thing you need is a good drill with a good mixing paddle. The heavier the... Read More »
basement floor not level rjstallings Flooring 2 02-12-2007 04:29 PM
does the floor really need to be level before laying tiles? KUIPORNG Flooring 29 11-04-2006 01:56 AM
Level floor by raising d18lee Flooring 0 10-20-2006 05:39 PM
garage conversion need to level floor gwendda Flooring 1 03-19-2006 03:06 PM
need to level floor ~ garage conversion gwendda Remodeling 3 03-17-2006 11:35 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
