Old 06-12-2007, 01:14 PM   #1
Bad tile cuts
I just had a tile floor installed in my house. The tile was 18 inch tile and had 4x4 marble inlay placed between every other tile. The first install was horrible, the company has returned two times since to try to "repair" the bad cuts. The owner will come out tomorrow and he has said he will ensure it is done to "industry standards" every thing I see is very subjective. Are there any hard rules to use for the joint cut quality. There are several small chips in the tiles and the cuts are not precise and straight, but what constitues good enough?
krush is offline   Reply With Quote
Old 06-12-2007, 07:45 PM   #2
Home Improvement Guy
ron schenker's Avatar
Bad tile cuts
Hard to answer without pics or actually seeing the job in person
ron schenker is offline   Reply With Quote
Old 06-15-2007, 05:20 PM   #3
Tile and Paint contractor
Bad tile cuts
Yeah, do you have any pictures?
The only real remedy is to remove the sloppy cut tiles, cut new tiles with diamond blade on a wet saw and install.
Matt | tile contractor
Charlotte, NC
MattCoops is offline   Reply With Quote
Old 06-18-2007, 08:26 AM   #4
Bad tile cuts
I think “good enough” is very subjective. If you are not satisfied then it is not good enough. You are the costumer! Try to work with the contractor. If he thinks it is a good job then maybe asks for a little money off. If you can’t come to some sort of agreement then there is always Judge Judy. Take pictures!
HAASEMAN2003 is offline   Reply With Quote
Old 06-18-2007, 10:07 AM   #5
Bad tile cuts
Stick to your guns. If you compromise by receiving a discount, the company will think you accept the quality of workmanship.
Jeekinz is offline   Reply With Quote
Old 06-18-2007, 10:15 AM   #6
Bad tile cuts
Yes sorry for that advice without completing the thought. If you do except a discount, it is a new contract and forget Judge Judy!
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
Subway tile installation bigboyjoel Flooring 3 08-02-2007 08:15 AM
Tile over, or tile under? jeffyisfive Flooring 4 01-24-2007 12:29 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 03:14 PM
