Backsplash Install, Will This Be OK... - Flooring - DIY Chatroom Home Improvement Forum
Old 06-17-2009, 11:36 AM   #1
Rewards Points: 150
Backsplash install, will this be OK...
I have OSB meeting sheetrock. The OSB was behind a soffit that was removed.
the OBS meets the sheetrock and there is a small gap. Do I need to fill that with anything, or will the mud from the tile do that? Is it ok that there are two different surfaces?
dcd22 is offline   Reply With Quote
Old 06-17-2009, 09:44 PM   #2
Remodeling Contractor
mud will fill it fine, BUT no tile over OSB (Advantec is a type of OSB and is fine for tile, but you will not find this on a wall)
Old 06-18-2009, 01:00 PM   #3
Rewards Points: 150
is there any option for this? It is next to impossible to get out as it runs behind my hood and cabinet's. The total size is about 3" x 8" on either side of the hood.
The hood is tapered between the two cabinet's on the side.
I have a pic, but dont know how to attach.
Old 06-18-2009, 01:37 PM   #4
you will be okay. Or install 1/4" cement board over the entire are which will give you a better job overall.
Old 06-18-2009, 01:46 PM   #5
Rewards Points: 150
Thanks Bob.
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Diagonal Hardwood Install Advice JDeFuria Flooring 7 06-29-2009 04:35 PM
How do I fish the power cable without breaking backsplash Uncledan Electrical 27 06-12-2009 12:56 AM
Over range microwave install on brick backsplash passportsf Appliances 3 02-01-2008 03:19 AM
Install granite countertops first or stone backsplash?? ncoppola09 Remodeling 32 02-20-2007 02:00 PM
