Backerboards & Gaps In The Subfloor - Flooring - DIY Chatroom Home Improvement Forum
Old 04-09-2006, 10:18 AM   #1
Backerboards & gaps in the subfloor
We tore up vinil & 1/2 inch plywoods and then hardwoods. So we are now down to subfloor on a 90+ year old house and are planning on putting down tile. Went to a store & picked up 1/2 inch hardibacker board and want to start laying it down. I have one concern about us putting the boards down-there are some gaps between the boards-is that OK? or should we do something else before putting thin-set & screwing in the backerboards. Thanks!
sergv is offline   Reply With Quote
Old 04-09-2006, 12:35 PM   #2
What sustrate is ther now, are you talking about plank flooring or plywood sheets?, all backerboards have to be installed over plywood or OSB, never over demensional lumber.
R&D Tile is offline   Reply With Quote
Old 04-09-2006, 09:15 PM   #3
IHI
I always try to get at least a 1"-1/14" base prior to installing the thin set and backer board. So assuming your dealing with the typical old diagonal 1x subfloor, install new 1/2" plywood with screws in each joist, then install your thin set and lat down the backer board.
Kinda of a rough idea since we dont know exactly what your dealing with, but a push in the right direction none the less.
Website
IHI is offline   Reply With Quote
Old 04-10-2006, 06:48 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Actually 3/4" ply would be better and it must be exterior grade. DO NOT fasten it to the joists, only fasten it to the existing subfloor material. Same goes for the cement board, don't fasten it to the joists and be sure to stagger all CBU joints with the plywood joints so that one never matches up with another. The cement board (CBU) is what gets set into the fresh thinset and you don't want to use pre-mixed thinset for any reason. Leave a 1/4" gap around the perimeter of the area for expansion.
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 07:29 AM
subfloor question for hardwood installation metrokarl Flooring 2 05-16-2007 09:37 AM
BAthroom Subfloor Blaze25 Flooring 3 11-17-2006 10:06 AM
subfloor for laminate and tiles mf915 Flooring 10 05-18-2006 05:01 PM
COMPLETE subfloor removal alexschmidt Flooring 4 08-03-2005 12:15 AM
