Backerboard Layout - Flooring - DIY Chatroom Home Improvement Forum
Old 04-28-2011, 09:37 AM   #1
Backerboard layout
Installing backerboard in kitchen in prep for tile, and trying to figure out how to lay it out. It is a 9x15 room. I understand that I do not want 4 corners to line up, but am wondering if 1 seam can run continuous the length of the room so long as it does not follow the plywood subfloor seam? I have attached my plan here. I do realize that with spacing around the edges and between sheets, I will probably have to shave down some of the tiles on 1 edge. Any suggestions would be appreciated.
jbeaulieu is offline   Reply With Quote
Old 04-28-2011, 06:28 PM   #2
woodman58's Avatar
You are making to many seams. Take out the 2 x 3's on the right and left sides and just use a 3 x 5. Keep the center the same.
woodman58 is offline   Reply With Quote
Bathroom DWV Layout Problems grymes56 Plumbing 8 05-15-2011 09:00 AM
Backerboard, tile, tub installl kathyll Building & Construction 26 02-15-2011 08:35 PM
Is it proper to tile over chipboard if backerboard is first laid? wvueers2004 Flooring 7 10-13-2010 05:22 PM
Question about how to position backerboard for shower Swazzle Remodeling 3 08-03-2010 05:11 AM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 10:56 PM
