Backerboard - Flooring - DIY Chatroom Home Improvement Forum
Old 08-28-2012, 05:58 PM   #1
Backerboard
Is it ok to lay 1/4" cement backer board over existing linoleum flooring before laying ceramic tile or does the linoleum have to be removed ?
denislush is offline   Reply With Quote
Old 08-28-2012, 06:33 PM   #2
Pro
JetSwet's Avatar
Rewards Points: 502
Removing the linoleum would be the best case because even if it's glued down it will have some air under it which will cause movement. Cement board holds no structure for tile, so air can cause backer board to move and cracking thinset and or grout.
JetSwet is offline   Reply With Quote
Old 08-28-2012, 06:55 PM   #3
Rmove the Linoleum! I have tried placing backer board over a linoleum floor in a small bath. It has been about 2 years and I just bought new flooring to do the job over. The sales person at the home store said it would work..... Wrong! Take the time and do it right the 1st time.
bigguy55 is offline   Reply With Quote
Old 08-28-2012, 06:58 PM   #4
Pro
JetSwet's Avatar
Rewards Points: 502
Never go with the box store guys they aren't perfesionals.
Old 08-28-2012, 07:25 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 340
Jet & Bigguy are right, but don't go far enough. Chances are your vinyl is installed over 1/4" underlayment of some type. The 1/4" stuff needs to be at the curb too. Verify the layers you've got there and let us know in detail. If there is 1/4" wood, take it up with the flooring attached.
How old is the floor? If old, there might be asbestos involved. Let us know, take pics if you can.
Jaz
Old 08-28-2012, 08:21 PM   #6
Pro
JetSwet's Avatar
Rewards Points: 502
Got to leave room for you Jaz don't want to open and close case before you get here lol
Backerboard, tile, tub installl kathyll Building & Construction 26 02-15-2011 08:35 PM
Is it proper to tile over chipboard if backerboard is first laid? wvueers2004 Flooring 7 10-13-2010 05:22 PM
Question about how to position backerboard for shower Swazzle Remodeling 3 08-03-2010 05:11 AM
Install self leveling concrete ontop of backerboard then install tile? benshouse Flooring 7 01-04-2010 12:24 AM
Curved backerboard? mdalli Remodeling 7 04-22-2008 02:24 PM
