Backer Board Thickness - Flooring - DIY Chatroom Home Improvement Forum
Old 10-09-2008, 08:57 AM   #1
Rewards Points: 123
I've building a new house for myself. I've done most of it myself and plan on doing the flooring. I've got about 950sqft of tile to lay in bathrooms/kitchen.
My question is this: What is the difference in 1/4" board versus 1/2" backer board? Is it a matter of extra strength or would the 1/2" board just be overkill? My subfloor is 2 X 10 joists and 3/4' T&G Advantech plywood.
Also, is there any less expensive alternatives to hardie Backer?
poolecw is offline   Reply With Quote
Old 10-09-2008, 09:05 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Standard thickness for flooring application is 1/4". Keep in mind that when you install cementitous board onto a floor, and add tile or stone, you are raising the floor height.
1/2" cement board is generally use for wall tile applications.
We are installing 1/2" cement board next week on a floor, in an addition that we built, however, we adjusted the height of that floor's surface, to be even with the adjacent floor heights. You can't do that with normal installed floors. Stick with 1/4".
- Build Well -
Old 10-09-2008, 11:14 AM   #3
Registered User
Termite's Avatar
To elaborate, it isn't a strength issue. Backerboard will flex, so the backer is reliant on the subfloor to provide rigidity. 1/4" is fine for floors. Be sure to bed the backerboard in thinset and screw it down, as well as mesh tape and thinset the seams. Definately don't want to skip any of those steps.
Personally, I don't buy the Hardiebacker. I use wonderboard or durarock. They're probably a buck cheaper I'd guess, but they do the same thing.
Old 10-09-2008, 02:30 PM   #4
Tile Setter
Backerboard has no structural value, so either one is fine. Typically 1/2" for walls and 1/4" for floors, but you can use the 1/2" on floors if you need the extra height, which is only the case in unique situations.
- Bob
Tileworks is offline   Reply With Quote
installing hardy backer board around a tub mrombs Kitchen & Bath Remodeling 8 02-11-2012 12:00 PM
Hardie backer board DXS General DIY Discussions 2 03-17-2009 06:40 PM
Thinset under concrete backer board? dankreboot Flooring 15 06-06-2008 04:55 PM
Painting DensShield tile backer board warriorfox Painting 2 05-15-2008 05:08 PM
Backer board vs. plywood for tile underlayment allpraisebob Flooring 4 01-07-2007 08:44 PM
