Azek Decking And Cortex Screw System - Flooring - DIY Chatroom Home Improvement Forum
Old 08-27-2010, 10:26 AM   #1
Azek Decking and Cortex Screw System
I'm having Azek decking installed using the Cortex screw system and having some problems.
The Cortex screw system is a little device that goes in a drill bit. It consists of a screw bit, spring, and nylon washer. The idea is that the bit drives the screw through the Azek decking to a specific depth as determined by the nylon washer. The screw is designed to ream out a slightly larger hole above the screw head to accept a plug that comes with the screws.
The problem is that the nylon washer is creating a round depression in the surface of the Azek.
Does anyone know how these dents might be repaired?
Incidentally, a Cortex rep told me that it is imperative that an 18V cordless or 1 inch corded drill be used to install the screws in Azek. My crew is using an 18V cordless but it's still leaving the impressions.
EdtheC is offline   Reply With Quote
Old 08-27-2010, 01:34 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
sign up here,lots of specialized deck pros that can help you
http://www.contractortalk.com/index....FZJd5Qoday-J9g
Tom Struble is offline   Reply With Quote
Old 08-27-2010, 08:48 PM   #3
SDC
SDC's Avatar
I have done thousands of SF of this decking and fastener system, I cannot say I have had this problem
SDC is offline   Reply With Quote
