Attic Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 12-12-2011, 01:50 PM   #1
Attic flooring
I'm finishing an attic and the floor is 3/8 inch ply that is in no way smooth. I actually have 2 questions.
1) is 3/8" thick enough for, say, living room traffic?
2) I plan on using peel & stick carpet tiles on the floor. Would primed 1/8" or 1/4" hardboard atop the 3/8" plywood be a good surface to install the tiles on? I'm trying to do it on the cheap.
Chestersthing is offline   Reply With Quote
Old 12-12-2011, 08:20 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 346
Hi Chester,
It all depends on how the space will be used, but if there's a potential for "normal" usage in the future, the minimum subfloor thickness should be 5/8". However since you already have 3/8", you should not go any thinner than 1/2" over what is there now. What are the joists' size and spacing? What is the span of the joists? How will the room be used?
So.........
Absolutely not.
Nothing 1/8 or 1/4" is gonna add much strength. Waste of time and money. Going "cheap" usually cost too much in the end.
Jaz
Old 12-12-2011, 09:31 PM   #3
Originally Posted by JazMan
Hi Chester,
So.........
Absolutely not.
Jaz
Thanks Jaz, will pick up 1/2". Floor joists are 2x10's 16" oc. 1/2" finished 1 side should do the trick.
Old 12-13-2011, 08:29 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 346
Underlayment grade is usually called B/C pine with exterior glued veneers. Exposure 1 is another term. Just don't buy the cheap CDX sheathing. Sheathing is not for underlayment. Sheathing is to apply the exterior surface of your shed or garage.
Jaz
Old 12-14-2011, 08:15 PM   #5
Jaz
I was mistaken, the underlayment is 5/8". What should
I put on top to give me a nice smooth surface for peel & stick?
Old 12-14-2011, 08:41 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 346
OK, sounds better. So the 5/8" is the subfloor, (there is no underlayment, yet), and you say it's not in good shape. If it's flat and structurally good, I would be OK with 3/8" underlayment. Certain grades of 1/4" birch panels made for flooring underlayment will be fine too. Just don't buy cheap 1/4" ply and especially don't buy what is commonly known as luaun.
Jaz
asbestos in our ripped up flooring?? 6fthook Flooring 16 07-29-2011 11:06 PM
Ventilating attic with two roofs senorbungle Building & Construction 2 01-09-2011 04:17 PM
Insulation, Ventilation in Cape Cod Side Attic Get'n er done Building & Construction 10 12-02-2010 11:38 PM
Attic fan options P550 Roofing/Siding 1 08-22-2010 12:47 PM
Re-flooring an Attic Bedroom gsgraber92 Building & Construction 3 01-18-2009 09:24 PM
